20,000 mile maintenance
Old Jul 21, 2004 | 02:18 PM
mitchapalooza's Avatar
7th Gear
Has anyone performed 20,000 mile maintenance? What services were rendered? Dealer cost?
Also, does dealer/acura maintenance schedule differ from maintenance minder system?
Old Jul 21, 2004 | 02:35 PM
rets's Avatar
Moderator Alumnus
I don't know what services or inspection items dealers are going to give to you at 20k milestone. But lots of dealers do have their own maintenance schedule instead of following 04TL's MID reading or info.
You tell them A1, they tell you 3750/7500 miles inspection with $130 plus. Telling them B would recieve another 7500/10000 miles check list with $130 plus. We follow A/B 1/2/3/... by MID and owner manual, they follow their own system, pretty like 2G TL's.
how Acura headquarters have trained their dealership...
Old Jul 21, 2004 | 02:55 PM
Ron A's Avatar
Administrator
You can't really use the term "20,000 mile maintenance", because everyone's individual driving habits, locale, etc, will determine when the MID tells you to do whatever you need to do, and this may be at 10,000 miles or at 30,000 miles, or any other figure.
The A maintenance is just an oil change and should only cost you what a regular oil change costs, plus tire rotation if they do that too. The B maintenance is virtually the same as the A, except they are supposed to check a bunch of things. These are the same things they are supposed to check when doing any oil change on any car, so there shouldn't be any additional charges for it. So, this means the A and B should be the same price, but of course, they will charge what they think they can get.
rets is right about dealers playing dumb and trying to get more money out of you. If you do your own maintenance, you will save a bunch of bucks, if you go by the MID you will spend some, but if you let the dealer screw you, I hope you're rich.
I don't think there is a question of how Acura trains their dealers, but how it lets the dealers try to snow you.
Old Jul 21, 2004 | 03:11 PM
7th Gear
Thanks for your replies. The car is telling me A1 (oil change) - Acura dealer is telling me 100+ dollars of check this and that + the oil change.
Old Jul 21, 2004 | 03:23 PM
Tripp11's Avatar
Newbie for Life
Stay clear of the stealers....I mean dealers and you'll be just fine.
Find yourself a trustworthy mechanic and save yourself $80 or so.
Old Jul 21, 2004 | 03:27 PM
ensley696's Avatar
$100 + for a friggen oil change? Damm, I really wanted to use the dealer for my oil changes too, oh well. Wonder what the Honda dealers charge?
Old Jul 21, 2004 | 03:32 PM
abtl's Avatar
I haven't had any maintenance done yet. However, if we change oil and rotate the tires ourselves then will the Acura warranty still apply?
Can Acura screw us up for not getting the maintenance done by an Acura dealer?
Will the maintenance minder light automatically go out if we do an oil change ourselves?
AB
Ron A's Avatar
Administrator
A=oil change, 1=rotate tires. There ain't no "this and that".
Can you do your own maintenance? Oil filter very easy to get at, costs around $7.50 at dealer, plus 5 quarts (use 4.5) of oil, around $8.00 at Walmart depending on brand,
Rotate tires also easy if you have a floor jack and stands, otherwise find out exactly what the dealer will charge for it. Be careful about who does it because there are many reports of shops scoring the wheels with the socket when they remove/install the lug nuts. Ifyou have a mechanic/shop you trust, that is your best bet.
Old Jul 21, 2004 | 03:34 PM
Ron A's Avatar
Administrator
AB
The owner's manual specifically states that doing your own maintenance will not void the warranty.
The MID will not reset automatically, but here are the instructions:
Pg 196, owner’s manual
Here’s the full procedure to reset the MID display:
1. Turn the ignition switch to ON
2. Press the < or > button repeatedly until the oil life is displayed.
3. Press and hold the Select/Reset button for 10 seconds. The Multi-Information Display will ask for a confirmation.
a. If you are sure you want to reset the display, press the Select/Reset button for 10 seconds again.
b. If you do not want to reset the display, press the < or > button to select “Cancel”
Old Jul 21, 2004 | 03:48 PM
Tripp11's Avatar
Newbie for Life
Can't give any more Reputation Points to Ron A, but you're all over it again!!!
U DA MAN!!!
Old Jul 21, 2004 | 03:53 PM
7th Gear
Any concerns with the placement of the floor jack and jack stands? Is this detailed in the owners manual?
Old Jul 21, 2004 | 04:55 PM
Ron A's Avatar
Administrator
Ask and you shall receive. See this thread http://www.acura-tl.com/forums/showt...508#post853508
Old Jul 21, 2004 | 05:00 PM
Ron A's Avatar
Administrator
U DA MAN!!!
Thanks. I can't give you any either. I even gave boltjames some just so I could give other people points again, so you can see I'm trying.
Old Jul 21, 2004 | 05:02 PM
rets's Avatar
Moderator Alumnus
Inside Garage, there is a thread "where to jack", http://www.acura-tl.com/forums/showthread.php?t=85473
Edit: Ron A posted the same thread while I'm doing the search... my bad, the redundant one...
Old Jul 21, 2004 | 05:04 PM
PoochaKannInc's Avatar
Shift_faster
Old Jul 21, 2004 | 09:20 PM
Road Rage's Avatar
Not a Blowhole
AB
Of course not. Plus, I plan to over-maintain my car - will that void anything? Of course not. You have to eset - Ise my OBD scanning tool, bit it is in the manual.
RTFM!
Actually, as good as my Acura delaer is, for inspections and stuff, I go to my Honda dealer. They can do warranty repairs on Acuras. Since I do all the rest of my mainteneance, it comes down to how I am treated, loaner, etc. I only bring my car in for stuff like having the steering wheel straightened, or warranty service > $100, or requiring special tools even I do not have (and I have a lot).
Old Nov 13, 2004 | 01:39 AM
T-Mobile's Avatar
I have been going to Santa Barbara HONDA for my oil changes. They cost me $23.99. The first time was great. The second time (22,000 miles) they could not get the information display to reset. Eventually they wen on line and got it, reset my display nd I was on my way. My only concern now, are they using the correct filter? I hear our cars have a tiny filter. Is it the same one as the accord V6???
Old Nov 13, 2004 | 05:09 PM
Ron A's Avatar
Administrator
Our filter fits several other Acura models, but from what I found doesn’t fit any Honda models. Here’s a link to a listing of the oil filters for Acura models.
http://www.acuraparts247.com/sunnysi...rd=Oil+Filters
The 2004TL oil filter part number is 15400-PLM-A02, which supersedes 15400-PLM-A01, which will also work. Check your work order; they may have written the part number on it. I don't think the part number is on the filter (probably too small to fit a long part number on the filter) but if you can get underneath the car you can take a look.
The A02 is supposed to be made by Fram, which some people don't like. If you are one of them, use the A01. You should be able to get either one at the dealer.
Zonian22
Nov 14, 2015 01:20 PM
Caddy
1G RDX (2007-2012)
Sep 18, 2015 12:44 PM
MyGuti
Sep 12, 2015 06:52 PM
EE4Life
Sep 11, 2015 10:09 PM
Zonian22
Sep 2, 2015 08:19 AM
