1st maintenance question
I looked online and if i recall the 1st maintenance is nothing but an oil change and inspection.
So anyway i just took it to Jiffy lube and got the oil change done there. This obviously did not reset the TL computer so now 3 weeks later i am getting the irritating maintenance reminder. SO...
1) How do i turn this off this reminder
2) Should i have taken it to the dealer for 1st maintenance?
donno y the computer is doing that, do u mean the oil cuz the service reminder in the manuel states that the service reminder is used when there is lik 30% left i think or less........ maybe its the computer not sensing the oil or smthing
When the MID is reset to 100%, the service interval starts over. This is post from Ron A:
The procedure on page 196 of the manual is incorrect. In paragraph 3a of the manual, the requirement to hold the button for 10 seconds the second time it is pressed is omitted. If this is not done, the display will not reset.
Here’s the full procedure to reset the MID display.
1. Turn the ignition switch to ON
2. Select Trip A or Trip B (You can use either one, so if you are using one to record data for something, use the other one to reset the Oil Life Indicator).
3. Press the < or > button repeatedly until the oil life is displayed.
4. Press and hold the Select/Reset button for 10 seconds. The Multi-Information Display will ask for a confirmation.
a. If you are sure you want to reset the display, press the Select/Reset button for 10 seconds again. (This is the part omitted from the manual.)
b. If you do not want to reset the display, press the < or > button to select “Cancel”
so will the computer not refresh the oil or detech the oil change until u do that???
This a TL Press Release posted by Brokedoc
The TL has a Maintenance Minder system that automatically monitors the vehicle's unique operating condition to indicate to the driver when maintenance is required. Maintenance alerts are presented when the ignition is first turned on, not while driving (to prevent driver distraction). The system monitors engine operating conditions such as fluid temperatures and engine speed to determine the proper service intervals. The Multi-Info Display (MID) located below the fuel and engine temperature gauges in the instrument cluster indicates the remaining percentage of engine oil life, and then shows service is due with a "wrench" icon. A percentage-based countdown to the next service is displayed when the car is within 15 percent of the end of the service interval. A letter and number code is displayed to indicate the specific type of service that is required. If the service is missed, the MID indicates past-due mileage to express the urgency of the required service to the driver.
The system is designed to eliminate unnecessary maintenance procedures, environmental impact and expenses, while ensuring that important service issues are addressed. In some cases, oil change intervals can extend to a maximum of 10,000 miles, which could spare the owner considerable money and inconvenience over the life of the car. The owner-resettable system monitors all normal service parts and systems, including oil, oil filter, tire rotation, air-cleaner, automatic transmission fluid, spark plugs, timing belt, coolant, brake pads and more.
Skirmich
Sep 15, 2015 06:41 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
