120 led drl ??
Old Feb 8, 2011 | 05:05 PM
MattB07TL's Avatar
120 led drl ??
Just bought an 07 TL and wanted to know if anyone has tryed the 120 led white drl? and also can I run the led's without getting one of those decoder sets? Thanks
Old Feb 8, 2011 | 05:44 PM
TRIOD3SIGNS's Avatar
SHAWD 04TL is in
hrm, 120 led DRL? sounds interesting... anybody have pics?
OP you might also want to run a search in the photography section.
Old Feb 8, 2011 | 06:40 PM
WhteTLS's Avatar
I have 96 LED DRLs now..
Here's my post from before with my 18 LEDs i think..
https://acurazine.com/forums/showpos...2&postcount=51
Also, you need to get this DRL Harness from V-LED.
Old Feb 8, 2011 | 06:46 PM
CubanLynx84's Avatar
under renovations....
Whom has 120 led drls?! I just got mine working using to seperate kits. At first I was just using the vleds kits but the harness didn't work with it. The bulbs actually worked without the harness then they just stopped working after awhile. I just recently ordered the ijdmtoy kit and its harness is different then vleds. Their bulbs however I didn't really like. In fact the vleds bulbs are brighter. So right now I'm using the vleds bulbs and the ijdmtoy decoder harness together.
Old Feb 8, 2011 | 07:04 PM
MattB07TL's Avatar
Thanks for the reply's , So the decoder is necessary I take it. I'm just gong to order the 120 LED's off Ebay and the decoder kit from ijdmtoy.Here's link to the bulbs in case anyone wants
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old Feb 8, 2011 | 07:24 PM
nate_0022's Avatar
Land of 10,000 lakes
It's says it needs 12v, don't our DRL's run at 9v or something like that?
Old Feb 8, 2011 | 07:33 PM
chuanger's Avatar
One or Two?
What decoder harness from ijdmtoy works with this? I too tried the V-leds DRL kit and the DRLs didn't work with the harness properly. The LEDs were still dim and they would stay on even after the car was completely turned off. I had to turn the car back on again to get the DRLs to turn off. Needless to say, I returned the v-leds drl kit for a refund.
Old Feb 8, 2011 | 07:37 PM
MattB07TL's Avatar
This is a link to the decoder kit I just ordered .Hope that helps
http://store.ijdmtoy.com/ProductDeta...DRL-Decoder-01
Old Feb 8, 2011 | 08:08 PM
The shipping is more than the bulb on that eBay link holy crap. Well to the op if you get them let us know how they work out for ya.
Old Feb 8, 2011 | 08:09 PM
chuanger's Avatar
One or Two?
That's exactly what i was looking for! Please follow up once you've got the 120 LED DRLs and the decoder kit installed. I'm curious to see the light intensity and output. I've tried several versions of the v-leds DRL kits for our car and all have not worked properly or have had very poor LED output. If they work well i'll bite!
Old Feb 8, 2011 | 08:13 PM
DMZ's Avatar
DMZ
Head a da Family
Though I like the idea of LED's for certain applications, some people here seem to suffer from LED-itus.
The whole idea of DRL's is just so other drivers can notice you. More brightness really isn't necessary during the daytime as it's more likely blind oncoming drivers. The DRL module I have lights up the fogs at 75% of their normal brightness, which intensity-wise just about matches most typical factory DRL's.
Unfortunately, the module I have is no longer made. :o(
Old Feb 8, 2011 | 08:24 PM
chuanger's Avatar
One or Two?
I dunno about the rest on this thread, but i'm not looking for HID intensity DRLs. My main reason for wanting DRL lights is for the color output. I enjoy the crisp white with slightly blue tint light better than the stock halogen ugly (imo) yellow colored DRLs. The problem with simply swapping out stock 9005s for 9005 LED DRLs is that the LED 9005s don't run properly on the lower voltage draw and the output suffers dramatically(they become so dim, you can hardly even tell if they're on or not), thus the need for the decoder. The brightness isn't going to be blinding or even close to a regular low beam output.
joflewbyu2
Aug 18, 2019 10:38 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
Froid
Sep 27, 2015 06:16 PM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
Cexarin
Sep 23, 2015 07:43 PM
