10mm or 11mm bleeder valve size
Old 09-14-2016, 02:28 PM
eastcoastguy's Avatar
I have looked and looked and cannot find a straight answer. If there has been one I am sorry for this post. The manual states the bleeder screw is 11mm but thats for manual cars, are the automatics the same or are they the 10mm like some have suggested?
Also, the correct hose size to put on the bleeder valve thats nice and tight but still fits, 1/4 inch dia or 1/8 dia. or something else?
Thanks for the help, this is the last thing I need to do to complete my brake job.
Old 09-14-2016, 02:30 PM
BreezyTL's Avatar
Received 1,033 Likes on 767 Posts
go put a wrench on it to figure it out?
The following 4 users liked this post by BreezyTL:
EvilVirus (09-14-2016), justnspace (09-14-2016), sockr1 (09-14-2016), thoiboi (09-14-2016)
Old 09-14-2016, 02:31 PM
Received 16,266 Likes on 11,974 Posts
lol some wrenches have two different sizes on them, 10mm and 11mm.
wouldnt be hard to flip it over if one side didnt fit
Old 09-14-2016, 02:33 PM
that doesnt help me if I dont have the wrench now does it? thanks for the answer!
Old 09-14-2016, 02:34 PM
BreezyTL's Avatar
adjustable wrench?
Old 09-14-2016, 02:36 PM
it's either or.
buy the two sized wrench. then you'll have 11 and 10 mm at your disposal.
Old 09-14-2016, 02:37 PM
are you trying to be a smartass?! is it that difficult to just answer a question?
Old 09-14-2016, 02:38 PM
itz cuz we dont know. I have a MT and its def. 11mm.
but like you said, there are reports of the autos being 10mm....
in that case buy the two sizes.
Old 09-14-2016, 02:55 PM
BreezyTL's Avatar
We aren't trying to be smart asses. You asked a question, got answers. Something so simple could be taken care of by yourself with a simple trip to buy an adjustable wrench and git-r-did!
Old 09-14-2016, 03:07 PM
"Put a wrench on it and find out" is not an answer" I understand I could have figured it out, but that's the point of a forum to ask a question to see if someone had the answer before I went and tried to "figure it out" If you dont know the answer then dont respond.
samplemonster (11-18-2021)
Old 09-14-2016, 03:18 PM
BreezyTL's Avatar
Forums are for questions to ask when you are stumped... Did you ever go out and try something before you took the time to write your question? I am sure it took longer to write the question than it would to go look for yourself. Something so simple shouldn't need a thread about it.
For example:
How do you open a box of cereal? Some people say you slip a finger under the flap and slide it to the side but you may get a paper cut. If you don't want a paper cut rip it in half. I don't know what to do!?!?
FFS, some people are so damn lazy these days!
Old 09-14-2016, 03:34 PM
UlsterBoy13's Avatar
oh snap, look what i searched for, very first post Page 19-18 has bleeder screw called out as 10mm.....
https://acurazine.com/forums/third-g...-041-a-578017/
im being helpful even though you are being rude dude...like they said you are gonna buy a 10 mm wrench, it will most likely have a 11mm on the other side.
The following 2 users liked this post by UlsterBoy13:
EvilVirus (09-14-2016), Oh Sickest TL (09-14-2016)
Old 09-14-2016, 03:45 PM
Jeff
Oh Sickest TL's Avatar
in his defence that was kind of a dick response lol. But I get it
Old 09-14-2016, 03:49 PM
BreezyTL's Avatar
seriously, it only takes a few minutes to figure this out. Its not like its a bolt inside the cylinder head that you can't get to until your whole car is apart... Sorry if you are a softy and can't take forum banter, but come on. If you can't figure this out you shouldn't be doing a brake change. Id leave it up to the profeshinals!
Old 09-14-2016, 03:59 PM
oh and 1/4" tubing from all the DIY's on here.
Old 09-14-2016, 04:01 PM
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
OP just buy a set of wrenches. You are going to need them anyway.
Test fit the 11mm and 10mm and see which one fits.
Hose doesn't matter as long as it fits over it (1/4 should be fine) or just purchase an oil bleeder kit.
Old 09-14-2016, 07:27 PM
Received 8,712 Likes on 6,719 Posts
OP, if you don't have a 11mm and ESPECIALLY a 10mm, you have NO business working on your car, the 10mm wrench is the master key on all Honda cars.
Spoonfeeding answers is definitely not something the more veteran members of this site like doing in cases like these where a quick search, or like everyone mentioned, running out there and just putting a wrench on there, or even better, having both on hand would solve.
You're old enough to have some common sense, utilize it.
Old 09-14-2016, 07:29 PM
And if you're unfamiliar with the Googlez, here's how you do it: Let me google that for you
Old 09-14-2016, 08:30 PM
Jeff
yea pretty much all hondas can be ripped apart with the 10mm lol
Old 09-14-2016, 08:43 PM
especially the bumper
Old 09-14-2016, 08:58 PM
Jeff
Honda bitch clips
Old 09-14-2016, 09:04 PM
The assumption is that I didnt use google or search acurazine to find the answers. I have been a member of this site for awhile and have seen people get flamed for not googling things so I know all about that. I did google it and search here on acurazine and could not find the SURE answer. This may be my first post ever, getting flamed for asking a question that was supposedly so easy to find. I saw that someone posted earlier that it was right in a certain post, well if I had found that post I wouldnt have asked. I do not appreciate being called lazy and/or lacking common sense both of which are not true. I could have purchased the wrenches and gone out and checked, but its the work week and I figured, "why not ask and check to see", wont do that again! There are a lot of assumptions going on and excuse me if like I said in my post I couldnt find something and even apologized for if it was covered and I didnt know.
Let a mod close or delete this as to not clog up the site with pointless posts.
Old 09-14-2016, 09:10 PM
Honda bitch clips
1 10MM /phillips head bolt on each end of the bumper in the fender wall...
You REALLY hate that bumper don't you
Old 09-14-2016, 09:11 PM
Nah, leave it open so that someone else in the future can hopefully search and find it without getting
Old 09-14-2016, 09:13 PM
Jeff
I like the way my paint looks
Old 09-14-2016, 09:26 PM
It's okay OP, it's the Internet, Here you go, I'll be helpful:
The reason why Service manual specifically says M/T are 11mm is because they use the Brembo 4 piston calipers (same as Type S). The A/T Base TL's will have a regular 2 piston caliper and per the manual, have a 10mm bleeder screw (highlighted above)
I think the confusion is people mainly refer to this page of the SM:
Jeff
jawknee FTW
Old 09-14-2016, 10:00 PM
Majofo's Avatar
Received 11,842 Likes on 8,573 Posts
I use my fingers to open and close the bleeder valve, because I'm not a pussy loser
justnspace (09-15-2016)
Old 09-14-2016, 10:26 PM
So Jawknee posts the same page I linked to and Jefe says he did all the hard work?! Fml...I suppose it's cuz I am foreign right? And I don't drive a Datsun? And I don't know what size socket to use to make my emblem glow??
i hate you all
EvilVirus (09-15-2016), Oh Sickest TL (09-14-2016)
Old 09-14-2016, 10:28 PM
Jeff
i hate you all
LMFAOOOOO damn dude I didnt see that . My bad! You da man. Fuck jawknee LOL
Old 09-14-2016, 10:33 PM
Fuck jawknee
SHOTGUN!!!!
To Cuck or not to Cuck.... THAT is the question
Old 09-14-2016, 10:35 PM
i hate you all
it's because you must not just post a link but the actual page ..
also i didn't see your post and just went through the entire SM to post it for OP
Old 09-14-2016, 10:37 PM
It's because you blocked me isn't it??? And no one quoted my helpful post!!!
i forgive you!
Old 09-14-2016, 10:38 PM
who's talking?
Old 09-15-2016, 06:22 AM
probably would have been easier to catch a ride to the autoparts store to fetch a wrench that had 2 sizes on it. preferably the 10 and 11mm that you needed.
but what do I know.
Old 02-03-2019, 02:25 AM
Steven Sparrow's Avatar
You're a dick head
no shit Sherlock WTF you're a head
everything is obvious the guy is clueless and is asking for help don't get smartass answers that's okay help him just makes you look more of a dick head
Old 02-03-2019, 06:10 AM
Late to the 3G Party
mb.3g's Avatar
Let's revive a three year old thread to hurl insults... HUYAH!
Old 02-03-2019, 08:25 AM
Majofo's Avatar
RIP AltarBoi
In the ass!!!
We are dick heads, so suck us
Old 02-03-2019, 08:26 AM
Majofo's Avatar
We don't just give out answers
But if you want some tips
We'll give it to you
#justthetip
EvilVirus (02-04-2019)
Old 02-03-2019, 08:28 AM
Latent car nut
horseshoez's Avatar
Received 2,019 Likes on 1,416 Posts
Time to put your Nomex on dude, the stunt you just pulled is not going to gain you many friends.
