100k plus problems
100k plus problems
Ok I have a 04 auto with 110k on it my list of repairs is
starter
head gaskets
Tail light led board
Water pump, timing belt
I think ive been somewhat lucky bought it with 30k on it. What are some of the repairs y'all have had to make so far?
starter
head gaskets
I've done nothing but preventive maintenance on my 04 TL with just under 120,000 kms!
new brake pads (still original rotors)
new tires
new air filter
new cabin air filter
new wipers
trans fluid change
brake fluid change
oil changes
Nothing else.
Not a thing has ever failed on my car yet. I thought my torque converter was about to go because I started hearing a scraping sound when in D but then the sound went away and hasn't come back (I'm not even sure it was the transmission). I expect to sell this car in about 2 years when it'll have about 150,000 kms and I don't expect it to need anything further for as long as I own it except oil changes and maybe another air filter and brake fluid change in a few months.
new tires
new air filter
new wipers
trans fluid change
brake fluid change
oil changes
Nothing else.
Bought my car at around 95K on the odometer. Yesterday I hit 111K and my car has been good to me so far ( in terms of nothing major has happened ::knock on wood:: )
A month ago the door actuator started malfunctioning and the inside door handle cable snapped. I have the parts in hand but my tools are at back at home (I'm in school now). So for a month I've been opening my door by rolling the windows down and pulling on the outside handle. It's pretty embarrassing but it's not a huge deal.
Other small things such as certain interior LEDs are out and a little rattling in the rear speakers. Nothing major thus far though.
I bought mine with 73k and I'm at 101k now. Just dropped it off for the 105k service. Problems I've had so far:
-Water leaking under the rear seats
-Over half of my dash lights are out (mostly the buttons around the navigation)
-Brakes feel really soft (getting the system flushed, but I don't know if that will fix it)
Nothing major really and I've taken this car across the country. I'm worried the clutch won't last much longer though.
my tl have 110k miles on it, and so far im experiencing some weird startup issues.
just the other day, my car made this heavy scratch noise when starting up the car.
on occasion....my car doesnt seem to want to start up right away like as if its low on gas or something (the tank is always a quarter full)
seems like when my car start...it would make a loud combustion noise....weird.
(i changed the sparkplugs with ngk iridium a few months ago -- i did it myself...im wondering if i torqued the plugs too tight such that the plug is deeper in the engine then it should? -- i would hand tight the plugs and then turn the ratchet 1/4 of a turn to tighten it)
Im at 63k and I haven't done anything other then maintenance items. I just ordered new hood struts since mine are starting to give out. Other then that, this car is pretty solid. knock on wood
Yea comptechtl that's what the dealership said about the head gaskets. The thermo stuck only once and it ran hot only once. Fixed the thermo and it still boiled over in the over flow tank so I took it back that's when they told me it was the gasket. They told me 3000 to fix it so I left. Did it my self for 1500 and thats with a race shop making the heads better.
Gaskets really didn't look that bad. But when I was removing the front head I noticed that two of the 8 head bolts where just sitting in the hole. When I pulled them out all the threads from the block where on the bolts. So I put timecerts in and had no problems since then that was 15k ago
I bought it with 73k miles (one owner) so I don't know how it was driven before. What concerns me is if I bring it up to higher RPMs and shift semi quickly, the clutch feels very stiff afterwards and slowly goes away. Also, the engagement doesn't feel consistent all the time starting off in first gear. I'm guessing that's just mostly due to the delay valve but sometimes it feels like it's just not grabbing like it should. I use Honda MTF for the transmission.
I've researched the problem on these forums and other people have the same issue. I have also read some folks that had this symptom replaced their clutch and it went away, so I'm not sure if it's a sign of the clutch on its way out.
I changed my clutch and all is well.
https://acurazine.com/forums/3g-tl-2004-2008-93/take-look-slightly-abused-clutch-797628/
Yeah I saw your thread. I'm suspecting my clutch is slowly on its way out as well. I'm just too broke at the moment to get the clutch replaced. The dealers charge an arm and a leg for a clutch replacement so I think I'm going to go the route you did and find a local shop. Problem is, I have a hard time trusting shops with my car... so I gotta do some research and find a reputable one. Hopefully it will last me at least another 4-5 months though...
SidhuSaaB
05-30-2020 12:40 AM
Fool
03-10-2016 08:42 PM
