'08 Type S Maintenance Recommendations
I just hit 120,000 miles on my '08 type S. I did the timing belt, water pump, tensioner, & compressor belt replacements at 100k miles. I also changed out the transmission fluid using the 3x3 method at 100k miles.
I'm just looking for recommendations on any maintenance I should of already done or I should plan to do soon. I have bought new spark plugs but have not changed them out yet. Is there anything else I'm missing? Like coolant replacement, etc.?
Thanks for the help!!
Coolant Flush
Brake Fluid Flush
Power Steering Flush
Inspect/Replace Compliance Bushings
Inspect/Replace Sway Bar End Links
Inspect/Replace Intake Filter
Inspect/Replace Cabin Filter
Top Off Blinker Fluid
Top Off Washer Fluid
Check/Clean Battery Terminals
Brake Fluid Flush
