07 TL-S decklid clips and bolts
Old May 29, 2007 | 12:37 PM
bforbrian's Avatar
Does anyone remember how many of each kind of clips and bolts come with the spoiler, and where they are put in the spoiler?
From what I remember, we get 3 white clips, 2 green ones, and 2 metal bolts..
where do these exactly go under the spoiler? I know that there are 7 holes.
Old May 29, 2007 | 01:00 PM
SteveP66's Avatar
Kaa - Ching !!!
From: Rhode Island.....Self-Proclaimed Chromed Cousin of Brettallica
3 white with a yellow piece that receives the white post - 2 blue plastic studs and two bolts.
White on each end and in the middle - two blue studs middle (each side of middle white) and two bolts each end inside of the white clip.
Hope that helps
Old May 29, 2007 | 01:13 PM
bforbrian's Avatar
Thanks steve, that's pretty much what I needed.
But I realized that I don't have the yellow pieces haha, but it still fits in
Old May 29, 2007 | 03:30 PM
SteveP66's Avatar
Kaa - Ching !!!
No problem, the yellow pieces help to hold the white tips ......
Old May 29, 2007 | 05:53 PM
bforbrian's Avatar
i don't know where they are how might i get a hold of those very very specific parts hahaha
will it not do the job if i don't have the yellow pieces?
Old May 29, 2007 | 06:09 PM
SteveP66's Avatar
Kaa - Ching !!!
Any dealer should have the nuts & bolts & clips.....
Here's a peak from an old thread - but since then I've learned the bolts do come off. You can see all the parts here.......
https://acurazine.com/forums/showpos...7&postcount=88
If you want to use the white clips you need the yellow pieces. Most have used all 3M or some 3M and 2 bolts........ you'll see in the thread
Old May 29, 2007 | 08:40 PM
bforbrian's Avatar
So if you want to install the spoiler I should either remove those white ones or use the ones only if i have the yellows?
Do you think the dealer will have the yellow pieces? I doubt it, since hardly any of the dealers I have contacted even have the spoiler itself.
tsx_boy
Dec 13, 2019 08:33 PM
Jul 16, 2017 07:33 AM
MetalGearTypeS
Aug 29, 2016 08:28 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
