'07-'08 TL-S HID Fog Light Install Question
Old Jul 10, 2014 | 07:49 AM
  #41
TRSAndrew's Avatar
Former Sponsor
Since fog light wiring generally isn't as thick as the headlights, I generally prefer to run the relay harness there for sure.
Our relay harness has a single input trigger, a power terminal, two outputs, and two ground terminals. Super simple to set up.
Old Jul 10, 2014 | 08:36 AM
  #42
Nick216's Avatar
The Boss
On the morimoto bulbs there the 2 single plugs that going into the ballast and than theres another connector that doesnt get used on each. but the bulbs worked fine. Atm i have those 2 unused and the oem car input not used on the passenger side. Because the relay is in the drivers. The extra plugs on the bulbs dont even connect to the bulb so idk what there for.
Old Jul 10, 2014 | 08:39 AM
  #43
Nick216's Avatar
The Boss
Also the bulbs seem to go in only upside down but the ground pattern looks perfect.Name:  image_zps4ffde97b.jpg
Old Jul 13, 2014 | 11:09 PM
  #44
vietxquangstah's Avatar
I know those 2 connectors that you are speaking of. They are included with the bulbs and are often not needed depending on the car.
They are 2 un-used (for us Honda/Acuras anyways) connectors on each bulb..
It's more like a extension adapter.
You may need to use them on only 1 side on Toyotas but for most Hondas they are not needed at all and I usually just cut the rubber piece and remove the connectors.
I believe on a friends Chrysler I had to use 1 or both sides.
Old Jul 14, 2014 | 08:45 AM
  #45
TRSAndrew's Avatar
Former Sponsor
Check out the install guide for the bulbs, which explains what those wires are: http://www.theretrofitsource.com/diy...ulb-guide.html.
space_boy
ILX
51
Aug 15, 2017 12:06 PM
theinsvnity
Sep 10, 2015 10:22 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
