'07/'08 tl
'07/'08 tl
So after I was settled on looking for a rwd 07 G35, I decided to go for a TL mainly due to reliability and maintenance - so is that a fact that 07/08 had different transmission or is this pure speculation
The 07-08 TL-S models have the RL tranny or so I have read.
Received 6,470 Likes
all 07 08 auto is different from 04-06 auto. (in a good way)
type S comes with air cooled auxilary tranny cooler
welcome to the site, you can register your color here https://acurazine.com/forums/3g-tl-2004-2008-93/tl-owners-please-chime-855960/ thnx.
Yes 07-08 running the modified version of RL AT which should improve than earlier model.
Series Motor's
08 is clutch and the base model doesn't have RL transmission, Type S have RL trans because it has a 3.5 liter block as well
^^^what the hell are you talking about? Base TL and Type S using the same AT regarless of 3.5 or 3.2 the only difference between the two is strokes the bore stay the same and WTH is 08 clutch? please don't give out fault info.
The following 4 users liked this post by truonghthe:
I have an 07 base and before I bought it I researched every bloody thing about the car, and ALL 07/08 models have a RL type tranny.
I guess it was the solution to the terrible tranny of previous years.
Series Motor's
Lol.... yea my goal is make sure everyone is misinformed and led down the wrong path -.-
I must be tripping out, cause I am pretty sure the type S trans is a lot bigger in size visually, is the type S one bigger for some reason?
^^^the only difference in AT between 07-08 Type S and 07-08 Base TL is that Type S has ATF cooler mounting on driver side in front of A/C condenser, Base TL doesn't have ATF cooler (unless you bought one and install it). Other than that it using the same AT.
Series Motor's
Damn sucks for me, the only reason I didn't want the base TL is because of trans problems and I figured that this one would actually be the best since I thought it is different, a little bit more sporty and upgraded like the motor; which means it can handle real driving without getting fucked up.
But fuck it, I got a superior deal, and always maintain the car myself. No problems what so ever =)
