'07-'08 Side Mirrors - Smoke Lenses
Old 01-31-2016, 02:24 PM
Life Connoisseur
MonkeyTrucker's Avatar
Does anyone know if you can get smoked lenses to match the same color of the TL-S side markers for the side mirror lenses?
Old 01-31-2016, 02:34 PM
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
You can try different tint vinyls for it
The following 2 users liked this post by guitarplayer16:
MonkeyTrucker (01-31-2016), Techneecs (02-01-2016)
Old 01-31-2016, 06:22 PM
jon.mar27's Avatar
i will like to know too, itll look a lot better tinted like the side markers
Old 01-31-2016, 08:38 PM
ggesq's Avatar
Received 2,181 Likes on 1,210 Posts
Some posts have been deleted. Folks, let's try and keep it civil here in the model forums. Thanks.
The following 2 users liked this post by ggesq:
EvilVirus (02-01-2016), MonkeyTrucker (01-31-2016)
Old 02-01-2016, 10:12 AM
Received 8,632 Likes on 6,667 Posts
VHT spray?
Old 02-01-2016, 10:59 AM
rockstar143's Avatar
Received 19,926 Likes on 14,464 Posts
I like the idea of vinyl so if you wanna remove it, it's easy...
if you do go VHT, make sure to buy enough cans to have enough for the job.
Old 02-11-2016, 08:49 AM
MyGuti's Avatar
Anyone tried anything with this yet?
Old 02-11-2016, 09:28 AM
GKinColo08TL's Avatar
When I had my TL I sprayed the mirror lenses with the same stuff I used to smoke my stock tails. It was simple and cheap and it looked good imho. I had a WDP TL so I only did it lightly. Sorry, no pictures.
MonkeyTrucker (02-11-2016)
Old 02-11-2016, 09:37 AM
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
cameras didn't exist back then, eh Gary?
GKinColo08TL (02-11-2016)
Old 02-11-2016, 09:48 AM
Kodak Brownie did...but then I'd have to get the photo developed, scanned and posted...so much work so little time.
(Pics I had of the TL are lost in cyber space somewhere, plus I don't think I ever took pics specifically of the side mirrors.
EvilVirus (02-16-2016)
Old 02-11-2016, 10:27 AM
Blue batmobile search him up
EvilVirus (02-16-2016), MyGuti (02-11-2016)
Old 02-11-2016, 10:37 AM
Alex.Leslie's Avatar
I picked up a couple feet of smoke Lamin-X this week and will probably install this weekend. I'll try to remember to report back with the results.
The following 3 users liked this post by Alex.Leslie:
EvilVirus (02-16-2016), MonkeyTrucker (02-11-2016), MyGuti (02-11-2016)
Old 02-11-2016, 01:27 PM
Life Connoisseur
Please come back with results.
Old 02-16-2016, 01:06 PM
Didn't do the install over the weekend. Will update when done.
Old 02-17-2016, 09:49 AM
I removed some this weekend...it is a pretty stark contrast with nothing on the lens. Now mine has condensation inside too
Old 02-22-2016, 11:06 AM
1999 House
Old 02-22-2016, 01:21 PM
Old 02-23-2016, 09:01 AM
Afdeng5's Avatar
Not quite the same topic, but has anyone else had an issue with discoloring around the outside of the sideview mirrors (on the glass itself)? Im wondering if it was from the previous owner leaving the heated mirrors on...
Old 02-23-2016, 09:04 AM
not even remotely the same topic.
replace the mirror glass https://acurazine.com/forums/problem...mirror-808102/
Old 02-23-2016, 11:21 AM
The heated mirrors shut off after a certain time...just like the rear window defogger so that's not the cause of discoloring...the cause is they're older...
Old 03-10-2016, 11:24 AM
Finally got around to installing the smoke LaminX on the mirror turn signals! Sorry for the long wait.
The Lamin-X went on easliy with a little bit of heat. The whole process (both sides), took about 30 mins to prep, lay, and trim. My friend who owns a vinyl company sourced the material and did the install with me, so I'm sure his experience helped. What impressed me the most was how the Lamin-X seems to completely restore the light below. the hazy look completely disappeared and the light now looks crystal clear.
rockstar143 (03-10-2016)
Old 03-10-2016, 11:27 AM
YES! Plus, I get some condensation inside when it rains, and the vinyl seems to help!
I actually tried using some old vinyl that was too thick and hard to mold. I ordered some much easier and better stuff now...
Looks amazing and yes, makes it glossy cause it's like you added a 2 mil layer of clear.
I may use the same vinyl over the fog lights to prevent a rock taking the glass out.
Alex.Leslie (03-10-2016)
Old 03-10-2016, 11:39 AM
Definitely put something on them! I had my passenger foglight smashed by a gravel truck on the highway. Picked up my $300 (CAN) OEM replacement. It'll go in once the gravel gets swept up.
Old 03-14-2016, 09:16 PM
Damn Alex, that one looks like it matches the sidemarkers perfectly. I bought some that doesn't match at all. Looks too brown. I need to find a lamin-x installer nearby.
Old 03-15-2016, 01:33 PM
That sucks! I didn't source this myself, so I don't have much to go off, but I believe we bought 'tint' which is their lightest colored material. From the website, you may have gone with gunsmoke? it looks a little brown to me.
As far as getting an installer, this is honestly super easy. I've worked with a bit of vinyl, and can lean heavily on my friend who owns the design/vinyl company, but with a heat gun and some patience, you could definitely do this yourself. Here's a rough DIY. You need:
Lamin-X
credit-card with lint-free towel (or similar tool)
heat gun
sharp (new) razor blade
cut more material than you need by a couple inches on each side (this lets you position and stretch without getting fingerprints under the part you put over the lens). clean the lens and surrounding area with all purpose auto or glass cleaner. Apply and press down in the center to seat the material. apply heat, and work from the inside out until all sides/edges are pressed down. trim carefully with the sharp razor (you don't have to cut all the way through Lamin-X. if it's scored, it will tear along those lines). remove excess. re-heat the Lamin-X remaining, and re-stick all edges. Done. Let rest for 48 hours before washing.
Last, Lamin-X can take a ton of heat, unlike regular sticker/overlay vinyl. My friend and I figured that a good rule is to place your hand next to the area your heating. Once your hand starts to feel the burn, then the Lamin-X is ready to be applied.
Good luck!!
Old 03-15-2016, 01:59 PM
Well, I certainly appreciate the advice. I've laid SOME down before, but not often. I actually bought some oracle vinyl, which isn't bad and stretches into place without heat, even...although I'm sure heat would help.
I talked to my buddy that paints and he tints clear with some black and said he should be able to match the sidemarkers so I'll let him give it a whirl first. If that fails...I'll follow up with the lamin-x for sure. Yours match PERFECTLY!
Thanks again, man.
J.
Old 03-15-2016, 02:01 PM
That's sweet, hopefully your friend has success with that. Stoked to see the results. Good luck!
Old 03-15-2016, 02:04 PM
just figured it out...you can order them in a roll...much more affordable than the pre-cut stuff that you better get right the first time! I don't mind sharpee and cutting!
Old 03-15-2016, 02:19 PM
Thanks, man...
another question, how much did you tuck and how much did you leave? I tried wrapping over the entire edge and it seems like it's way too tight when being pressed in which kinda forces some material out.
I might order a roll and just go this route and also do the fog glass.
Old 03-15-2016, 02:37 PM
for sure! I didn't even know they did pre-cut pieces for this lens. We have a vinyl whole-saler (sp?) in town, and were able to buy just a couple square feet off a roll.
we tucked nothing. we did it as I mentioned above, starting with an extra couple inches in all directions, pressing it down all the way to the edge of the reflector, and then trimmed it exactly on the line between the lens and the painted mirror.the trimming took the longest, since it needed to be perfect, and that's why I suggest a brand new blade.
LMK if you have any questions during the process, if you decide to go this route.
Old 03-15-2016, 02:40 PM
Thanks, man...Gotcha, that's what I'll do then too...trim exactly to the edge!
No, I meant I originally searched by car and found the pre-cut for the fogs and/or tails...but if they cut them for you, they're $50 for tails and $15 for fogs...whereas 4"x30' is only $30.
If I do go this route, I'll definitely post it here. Kinda making me doubt having them sprayed now since it's not guaranteed to be the right shade and the laminx is.
Rolex Paws
3G RLX Audio, Bluetooth, Electronics & Navigation
01-31-2016 06:52 PM
Quick Reply: '07-'08 Side Mirrors - Smoke Lenses
