'07-'08 Side Mirrors - Smoke Lenses
Does anyone know if you can get smoked lenses to match the same color of the TL-S side markers for the side mirror lenses?
i will like to know too, itll look a lot better tinted like the side markers
Some posts have been deleted. Folks, let's try and keep it civil here in the model forums. Thanks.
VHT spray? :shrug:
I like the idea of vinyl so if you wanna remove it, it's easy...
if you do go VHT, make sure to buy enough cans to have enough for the job. |
Anyone tried anything with this yet?
When I had my TL I sprayed the mirror lenses with the same stuff I used to smoke my stock tails. It was simple and cheap and it looked good imho. I had a WDP TL so I only did it lightly. Sorry, no pictures.
cameras didn't exist back then, eh Gary? :snicker:
(Post 15677843)
(Pics I had of the TL are lost in cyber space somewhere, plus I don't think I ever took pics specifically of the side mirrors. |
Blue batmobile search him up
I picked up a couple feet of smoke Lamin-X this week and will probably install this weekend. I'll try to remember to report back with the results.
Originally Posted by Alex.Leslie
(Post 15677903)
Please come back with results. :) |
Didn't do the install over the weekend. Will update when done.
I removed some this weekend...it is a pretty stark contrast with nothing on the lens. Now mine has condensation inside too :bored:
(Post 15682039)
1999 House
:blush:
Not quite the same topic, but has anyone else had an issue with discoloring around the outside of the sideview mirrors (on the glass itself)? Im wondering if it was from the previous owner leaving the heated mirrors on...
Originally Posted by Afdeng5
(Post 15686795)
replace the mirror glass https://acurazine.com/forums/problem...mirror-808102/ |
(Post 15686798)
not even remotely the same topic.
Finally got around to installing the smoke LaminX on the mirror turn signals! Sorry for the long wait.
https://cimg6.ibsrv.net/gimg/acurazi...5761223a6c.png The Lamin-X went on easliy with a little bit of heat. The whole process (both sides), took about 30 mins to prep, lay, and trim. My friend who owns a vinyl company sourced the material and did the install with me, so I'm sure his experience helped. What impressed me the most was how the Lamin-X seems to completely restore the light below. the hazy look completely disappeared and the light now looks crystal clear. |
YES! Plus, I get some condensation inside when it rains, and the vinyl seems to help!
I actually tried using some old vinyl that was too thick and hard to mold. I ordered some much easier and better stuff now... Looks amazing and yes, makes it glossy cause it's like you added a 2 mil layer of clear. I may use the same vinyl over the fog lights to prevent a rock taking the glass out. |
(Post 15700534)
Damn Alex, that one looks like it matches the sidemarkers perfectly. I bought some that doesn't match at all. :sad: Looks too brown. I need to find a lamin-x installer nearby.
(Post 15703460)
As far as getting an installer, this is honestly super easy. I've worked with a bit of vinyl, and can lean heavily on my friend who owns the design/vinyl company, but with a heat gun and some patience, you could definitely do this yourself. Here's a rough DIY. You need: Lamin-X credit-card with lint-free towel (or similar tool) heat gun sharp (new) razor blade cut more material than you need by a couple inches on each side (this lets you position and stretch without getting fingerprints under the part you put over the lens). clean the lens and surrounding area with all purpose auto or glass cleaner. Apply and press down in the center to seat the material. apply heat, and work from the inside out until all sides/edges are pressed down. trim carefully with the sharp razor (you don't have to cut all the way through Lamin-X. if it's scored, it will tear along those lines). remove excess. re-heat the Lamin-X remaining, and re-stick all edges. Done. Let rest for 48 hours before washing. Last, Lamin-X can take a ton of heat, unlike regular sticker/overlay vinyl. My friend and I figured that a good rule is to place your hand next to the area your heating. Once your hand starts to feel the burn, then the Lamin-X is ready to be applied. Good luck!! :thumbsup: |
Well, I certainly appreciate the advice. I've laid SOME down before, but not often. I actually bought some oracle vinyl, which isn't bad and stretches into place without heat, even...although I'm sure heat would help.
I talked to my buddy that paints and he tints clear with some black and said he should be able to match the sidemarkers so I'll let him give it a whirl first. If that fails...I'll follow up with the lamin-x for sure. Yours match PERFECTLY! Thanks again, man. J. |
That's sweet, hopefully your friend has success with that. Stoked to see the results. Good luck!
just figured it out...you can order them in a roll...much more affordable than the pre-cut stuff that you better get right the first time! I don't mind sharpee and cutting!
Thanks, man...
another question, how much did you tuck and how much did you leave? I tried wrapping over the entire edge and it seems like it's way too tight when being pressed in which kinda forces some material out. I might order a roll and just go this route and also do the fog glass. |
for sure! I didn't even know they did pre-cut pieces for this lens. We have a vinyl whole-saler (sp?) in town, and were able to buy just a couple square feet off a roll.
we tucked nothing. we did it as I mentioned above, starting with an extra couple inches in all directions, pressing it down all the way to the edge of the reflector, and then trimmed it exactly on the line between the lens and the painted mirror.the trimming took the longest, since it needed to be perfect, and that's why I suggest a brand new blade. LMK if you have any questions during the process, if you decide to go this route. :thumbsup: |
Thanks, man...Gotcha, that's what I'll do then too...trim exactly to the edge! :)
No, I meant I originally searched by car and found the pre-cut for the fogs and/or tails...but if they cut them for you, they're $50 for tails and $15 for fogs...whereas 4"x30' is only $30. If I do go this route, I'll definitely post it here. Kinda making me doubt having them sprayed now since it's not guaranteed to be the right shade and the laminx is. |
