05 TL Cruise Control location
Hi I am kinda new to the Forum but can anyone help me out with finding the cruise control module on the 05 Acura TL?
I have went through and checked that my cruise control button is working and staying down in place while activated. It as also NOT the brake light switch so last thing it could be is the module but where is it??? Can someone help please and thanks!
Is the #8 pedal stopper pad in place to work with the #6 Stop And Cruise Control Switch Assembly shown below?
But if it’s no cruise control module or cruise control box then is it integrated into the Throttle Body?
both fuses are not blown at all. Do you think replacing brake light switch will fix it? Although the switch is working as it activated the brake lights?
If you want to employ the 'parts cannon' it's yur call.
The next thing listed is the cruise control input test on the attachment.
The brake pedal position switch signal is the first test item on the list; though it appears you have to have the HDS system.
Check your tail-lights, if an LED is burnt out it will cause this issue.
D'Marco Flournoy (08-22-2022)
Bob Bertrand
03-03-2019 06:54 AM
