04 TL Window - Up and Down?
My 04 TL has a strange thing happen.
The passenger window sometimes goes and up down a few times before it will actually close.
Its like its possessed. What is going on? Ideas?
Thanks in advance
Thanks in advance
My car does the same thing and it started recently i also have an 04 TL and its only the passenger window as well and i searched but no one had this problem before
1 Post
I had that happen and took it to the dealer. They fixed it and said it was the window regulator. So if you're still under warranty, take it in. I think it's a relatively quick fix. Hope that helps.
do you guys have window visors installed? I have an 04 as well and this happened to me too but it was right after I installed my visors. Turns out I didn't put the rubber piece back around the window all the way and that was causing it to go back down. I fixed it and have not had the problem since.
If you press the button to put the window up, and it detects somethign in its path, it'll go back down. This is to prevent it from squishing your fingers. My guess is there is something fooling the sensors into thinking that there is something there, spiderwebs or something. Try cleaning all around the window.
Stay Out Of the Left Lane
Received 1,241 Likes
xsilverhawkx
09-28-2015 06:51 PM
AcuraKidd
09-25-2015 11:18 PM
