04 TL performance mods
The stickiest of the icky
Ok i have been out of town for a while so maybe i missed some stuff, so i am trying to catch up with you guys here. i have heard talk of ecu chips and exhaust upgrades, and would like to confirm what i have heard. please post the performance mods that have come out for the 04 tl. so far all i know about is:
CAI
lowering springs
...thats all i can think of. i havent done anything yet except for the dome lights, and i am trying to budget out my cash to see what are going to be my next mods. thanks
CAI
lowering springs
2005 WDP TL
I have heard that jet does an ECU reflash worth about 8 hp, I don't know if that is to the wheels though......THe exhaust everyone has been talking about is the comptech, I believe. You alsoneed to check on a rear swaybar.
CAI
lowering springs
CAI
lowering springs
critical thing to do is after all your mods, get the ecu remapped. the combo of larger injectors with a better breathing will balance each other, but a remap can tune the curves precisely.
with better breathing you can extract more power from the motor, then when you need a snap in your neck you hit the NoS.
Just to add....Comptech has just released a rear sway bar, and is in theory going to release a supercharger before the end of the month.
i dont really know anything about how nos works- how much does it cost to buy and install, how is it set up, i know there are different types (wet/dry), but do both only come into play when you press the nos button/put the throttle wide open, or does it come in through the entire powerband. thanks a lot for the responses
a fogger nozzle has 2 inputs, one for gas and one for NoS. both input flows are controlled by solenoids (one for gas and one for NoS). the fogger nozzle mixes the 2 as it exits the nozzle in your intake. this is the "wet" system.
if you want dry, i've seen many setups where the NoS is injected right into the airbox, but dry can make your engine run real lean when you get up into the 100-150 hp range, hence why bigger injectors are needed are are usually rigged so that when NoS is on injectors are wide open.
both setups are used WOT while rpms are up. NoS also usually requires some timing changes while NoS is activated, but smaller doses around 50-75hp should be ok with the ecu.
if you want smooth power boost throughout, you need a supercharger. if you want all out power you need turbo. if you want to run 1/4 mile race you need super/NoS or turbo/Nos setup.
fogger is the easiest way to get the best from NoS. my guess, simple kit will run you $400 or so.
Semper Fi
Originally Posted by kyle-wdp
Where can I order the rear sway bar from Comptech? Isn't it around 110 bucks?
AHUMMMMMMMMMMM AWWWWWWWW
A TL WITH A TURBO/NOS
IF they only made a turbo for us automatics
SO still DROOOOOL SUPERCHARGER/NOS DROOOOL
WERE would one get this NOS installed in the staten island area????
like reputable not a mom and pop place .. and not pep boys
Shift_faster
Originally Posted by Nodoze2004
Can anyone with the rear sway bar installed comment on the handling improvements?
I'm getting mine installed on August 27th.
Semper Fi
VTEC HoooA
Good deal thanks Ali! Hopefully I will still have the car.....as hurricane Charlie is going to be rolling through town in less than 5 hours. Fear not fellow TL owners she is safely tucked away in the garage!
Talk about dedication, we have a hurricane rolling through and I am on the boards
Shift_faster
Semper Fi
Are there pulleys for our car yet? I hope this isn't a stupid question as I didn't search first.....
Nodoze2004 I hope you and your family are safe also
mlody
12-04-2019 02:11 PM
InFaMouSLink
10-27-2015 06:52 PM
MrHeeltoe
09-28-2015 05:43 PM
