'04 TL door upholstery :(
Old 08-24-2012 | 10:28 AM
vicgreen19142's Avatar
I was cleaning my car this morning and I found this out.
What can I use to fix it?
Old 08-24-2012 | 10:29 AM
Jcaron9gt4's Avatar
I would just use some super glue and tuck it back in.
Old 08-24-2012 | 10:33 AM
super glue for upholstery
Old 08-24-2012 | 01:53 PM
ben2jz's Avatar
8th Gear
3M makes a product for upholstery. I always see it at homedepo. Don't use super glue. It will crust off.
Old 08-24-2012 | 03:53 PM
Steven Bell's Avatar
You can probably just tuck it in and it would be OK without the glue too.
EvilVirus's Avatar
quote[3M makes a product for upholstery. I always see it at homedepo. Don't use super glue. It will crust off.]qoute
^ agree due to the heat
Old 08-24-2012 | 04:40 PM
EATSLEEPRACE's Avatar
6SPEED FEVER
i used gorilla glue when my i had that problem in my old tl
Old 08-24-2012 | 05:45 PM
Jesstzn's Avatar
Try using a credit card to tuck it back in ..
Old 08-24-2012 | 05:52 PM
ParaSurfer1979's Avatar
I would agree with the fellow Administrator. Use a small flat head screw driver to push it back in the door
Old 08-24-2012 | 08:33 PM
VQPower37's Avatar
^ x2 best way to fix something is to not really add stuff if u dont have to IMO ... i would probably use velcrow or something like that ...
Old 08-24-2012 | 09:24 PM
aznandy26's Avatar
you can used "spray adhesive" from 3m they sell at home depot. and use a flat screwdriver to put it in. they use this adhesive to apply carpet on the sub box..good luck!
Old 08-25-2012 | 12:56 AM
Healingduck's Avatar
'07 TL Type-S
Same thing happened on my rear doors. All I used was some super glue and tucked it back in.
Old 08-25-2012 | 03:04 AM
MEKO's Avatar
Pushing it back in doesn't work. You don't even need a screw driver for that, could do it perfectly with fingers but it will come out again.
So yeah need glue
Old 08-25-2012 | 08:31 AM
Xiomaro's Avatar
1st 3g Turbo TL-S
use a dab of glue around the popped out areas then use a plastic scraper to tuck the upholstery back in place
Old 08-25-2012 | 10:15 PM
Thanks for all the great advices guys, I would sure pass by home depot to see if I could get some of that 3M clue for upholstery.
soupi
14
11-15-2015 11:15 AM
BIGxRED
10-19-2015 10:47 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
chiu0nthls
3G MDX (2014-2020)
09-28-2015 03:46 AM
ceb
ILX
09-27-2015 10:56 AM
Quick Reply: '04 TL door upholstery :(
