04 TL 3rd gear pressure switch
04 TL auto base...3rd gear pressure switch failure symptoms,,, what have you all experienced? My car runs, shifts everyway perfectly, just D light sometimes blinks. I'm putting in a new switch and changing fluid 3X's.
Issac Sanchez (06-25-2020)
My car, a 2004 TL, at about 190K miles, I was experiencing the 3rd gear shudder, a shake or hesitation in third gear just before shifting into 4th gear. It started as an intermittent problem, generally occurring as the car was warming up. First time it happened, I thought the shaking was me driving over a rough patch of road. Over time, it began to happen more often, and became more pronounced. There were no warning lights, and no flashing D light.
Had the 3rd and 4th gear pressure switches replaced, and did a simple drain and fill with DW-1. Wow, what a difference. 3rd gear shudder gone! And I was also previously having hard/clunky shifts at part throttle conditions...that problem was also gone with the replacement of the pressure switches, and drain and fill of transmission fluid. Now, it shifts perfectly!!!
MarkB3264 (06-08-2022)
So I have seen that from 2018 onwards MDX wheel PCD is again 5x120 very much like the 2G and dissimilar to the 3G which has 5x114.3 Does this mean a 2018+ wheel could be an immediate fit on my 2011?
sixsixfour
02-08-2022 02:59 PM
mrlobaloba
03-04-2010 06:41 AM
