03-05 Honda Accord 4Door Fog Light Mod
does the front bumper has to come off when cutting the bottom grilles? I bought the oem fog lights from ebay. I work and go to school at the same time, and I dont have time to do this myself. anyone has done that in the seattle Wa area? which shop did you go to and how much just for labor? I was thinking about going to cartoys to see if they can do it or not... please help and post some nice pictures of how they look like!
nice mod
Originally Posted by ua6spec
Yes you need to take out your bumper. Process will take about 2-3 hour if you have a buddy help out.
scared
Originally Posted by Tim L.'s TL
ua6spec, can you take close up pictures of the grilles you cut.. please take some pictures that shows the area where the grilles and fog lights touch each other.. thanks!
King of NYC
You will have to do some pretty extensive trimming on the foglight housing too. I decided not to cut my entire grille, when it meets the foglights. I left the outer ring. It's harder that way as chopping the whole thing is easier. I wanted to frame and secure the foglights with no shaking.
It's not easy to explain but a couple things to note is that if you have an A-Spec kit there will have to be some trimming at the lower outer corner. Also the Accord fogs have a slight angle on it's outer border. They angle outwards. The lower grille openings are straight horizontal and rounded off. You have to trim carefully to get it fit properly. It took me hours to get it right. Also there is an angle adjustment bolt that juts out on the bottom. I had to do some trimming on the bumper and grille to fit that in. I'm doing mesh grilles too so it is an additional headache. It is a big time headache finding a way to get this to all fit together. I was abut to chop the grille many times to make it easier but I finally got it.
My only problem now is finding a way to screw in the inner ends of the foglights where the holes for the screws are......I'm thinking of drilling holes into the bumper and zip-tying it? Originally I thought of fabricating an exotic bracket. I have HIDs in there, I don't want any shaking. Any ideas?
iWhine S/C 6MT TL
Its not hard just takes up a lot of time... I have to once again do this mod but for my brother. Family 1st
iWhine S/C 6MT TL
^ if you order it from honda i can help if you get it off of ebay your SOL
thanks for all the great pix! did you guys use the oem accord switch that came with the fogs or aftermarket ones? where did you guys mount them at? pictures will be very helpful once again.. lastly, merry x-mas to everyone!
iWhine S/C 6MT TL
^ I used everything OEM. Even the accord switch that came with it. I got everything to work and function 100% like if it was factory installed.
yea Gus the switch came out sick!!! I did a whole customized button scheme in mine
lol no trade on rims =) sorry bro gotta keep em theyre the only straight ones.
tim u got the blank slot next to the mirror control thats where he put it and it fits like a glove (not like oj's glove) he did a great job connecting it all up. I was totally blown away.
iWhine S/C 6MT TL
Yup thats where I put it, When i have any parking lights on the icon for the fogs light up and when I turn on the fogs the solid green light comes on thus making it 100% functional as if it was oem installed.
thanks for the kind words george!
iWhine S/C 6MT TL
^ I am sure you can but I wired them into the parking lights.
King of NYC
I used Ebay fogs. I'm sure the OEM ones are nicer. Forget the wiring, it totally dosen't make sense to me! I am putting in HID so I will rely on the wiring harness for that.
I have my lights and grilles all installed on the bumper ready to go on the car. I ran wires through the firewall. I am waiting on a ballast, but I need my car drivable within 2 days so I will only totally finish this mod next month.
I wish I could use the blank next to the mirror switch but I already used it for DCC's switch. My center console has a DVD player and PIEX3 switcher in it and will later have my V1 display. I guess I will use my ol' blue LED toggle switch I have lying around. Thing is where the heck should I put it?? I already have a blue LED switch near my leg on the lower side of the front console.
Are these the same fog lights you used for the conversion of the 04-05 honda accord fog light into the acura tl 05? please and thank you.
-------> http://cgi.ebay.com/ebaymotors/03-04...spagenameZWDVW
UCFneo
I found this on ebay:
http://cgi.ebay.com/ebaymotors/03-04...ayphotohosting
Are these the OEM fog lights you guys used?
Also, once you cut out the slots in the grill, how do you make the fog lamps stay tightly in place? Any suggestions?
Originally Posted by UCFneo
I like those, but I want the same thing with the clear lenses instead of the yellow ones
