0 to 60 - SportShift vs Automatic Reg
Originally Posted by MichaelBenz
Thats going to be very subjective there. Depends on the driver.
You're only shifting once from 0-60, so it wouldn't even really matter, would it??
Originally Posted by HiTEC
Other than shifting at a different RPM, I don't see how skill is involved in driving a sportshift automatic?
That pretty much would be the only reason to use SS mode....
That's what I figured. In past cars that I've owned with auto (tip, step, etc tronic) transmissions I always found it best just to put it in sport mode and let the transmission do it's thing rather than try to shift on your own for straighline acceleration.
Originally Posted by ndx2
True - doesn't the ECU learn the way you drive and shift accordingly? The 2G's allowed the driver to stay in 1st, but the 3G's AT only as L (correct me if i'm wrong) so even gateshifting wouldn't help, imo.
Originally Posted by geekybiker
Biggest question for 0-60 times is "how many shifts to get there? Can the TL get to 60 in second with a manual? Auto's usually can, and they shift quicker than most people.
I don't want to turn this into a manual vs auto thread because everyone knows we've had too many of those.
Yes the auto shifts quicker than most manual drivers, but the manual doesn't have a torque convertor to loose power on the way to the wheels. That's one of the big reasons why the manual will be quicker because it puts more power to the ground than the auto.
I dislike 0-60 times anyway. Id rather see drag slips for comparing acceleration. That way we can look at the 60', ET, and Trap.
well, that's why I was asking how many shifts to 60. 6spd gearboxes are often slower to 60mph than their 5spd counterparts just becuase they require an extra shift. Same number of shifts the manual is normally quicker for the reasons you mention. (well stock anyways.)
Originally Posted by JJaber06
How much power does the torque converter take away?
Originally Posted by bluenoise
The 5AT can reach about 68 in second gear, if I recall, before hitting the redline. So the only shift in SS or Auto is the first-to-second and it's automatic in both cases.
Not if you use both gates to shift. Right hand side all the way down to start...and when it winds up....shift to SS mode. I do it all the time...daily. Keep it in first though the use of low and then shift to SS mode when you want second. Kind of a hassle...but you get used to it pretty quick and it comes second nature after that.
True, but then you're not really in SS or Auto the whole time (yeah, I know...it's a technicality...).
guyvelella
Sep 30, 2015 11:02 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
