Losing tire pressure
my wife's 2014 RLX loosing tire pressure... There is no damage to the tires or any nails. It happens often when the temp drops outside. I understand that the low profile tires don't hold as much air as the regular ones but the pressure drops from 240 psi to 190 and the low pressure alarm goes off...
Have anybody else expirienced this problem?
No issue on the my '16. Tire damage is sometimes hard to see with the naked eye. It doesn't take much for a slow leak to occur. You may have run over something you are not aware of. Could also be a loose/worn valve stem. Might want to have it looked at.
justnspace (07-18-2017)
Ideal gas law states when temp drops, so can pressure
Tire pressure should always be tested/filled up when cold. 240 refers to kPa (because canada) which is a tad under 35 PSI for us American folks. 190 kPa = 27.5 PSI. Fill up to 240 kPa when cold and keep watch.
That being said though, , but 20% drop is pretty steep so it may be a loose valve stem as mentioned above.. Take it to a tire place so they can check the entire tire.
I often see a similar drop in tire pressures during the winter months. We have a heated garage (which we keep at around 15C (59F) and outside temperatures below minus 30C (minus 22 F) are not unusual around here and that big a temperature drop will lead to a substantial drop in tire pressure. In the winter months, we add at least two or three psi (13 - 21 kPa) extra tire pressure so that the pressure does NOT drop too low if the car is outside in the cold for a few hours.
The key to discovering if you have a leak or not is to monitor if the tire pressure returns to normal when the car is in a warmer environment (garage for example). If it does, you are experiencing normal temperature related pressure fluctuations and simply keep your pressures higher than the door sticker recommendation during the winter months so the TPMS alarm is not triggered. If the pressure does not return to normal, get thee to an Acura dealer or tire shop and have it checked out - you have a slow leak.
Just my two cents.
Just my two cents.
Thank you guys, that's all makes sense. The drop of the temperature happened in a summer and not in a winter. I'm talking about from +30C to +17C. So most likely I have an issue with a slow leak - may be a valve. Off to go to the tire shop....
hondamore (07-18-2017)
I have the same issue. When it gets hot and cold I lose about 5 psi of tire pressure on two of my wheels. I have cracks on the side wall so I think that would be my issue.
justnspace (07-20-2017)
Ok so I took the car to the shop. No problems with tires or valves at all.... They pumped up the pressure and told me to keep an eye on it. Will see what's gonna happen.
Scratching my head on this one. Seems to me if the tire is repeatedly suffering a pressure loss, something is amiss. You have already put air in the tire and it seeped back out. To me, that is a problem. Maybe you just needed Acura air. Hopefully that was free!
If all four tires are inflated to the recommended pressures and a drop from 30 degrees to 17 degrees causes the TMPS to be triggered, then there is a problem with the TPMS system. My guess is that your wife's tires were a "bit low" to begin with (but not low enough to trigger the TPMS) and then the drop in temperature was enough to drop the pressure below the threshold for the TPMS warning. Fortunately the TPMS system did its job and warned your wife to top up the pressures before they were low enough to do damage to the tires or become dangerous to drive on.
My old man advice is to click over to the TMPS in the MID at least once a month and check the pressures in your tires. If they are even a bit below the recommended level, top them up. That way you are always at the optimum inflation for the best handling and safest driving.
Just my two cents.
Just my two cents.
justnspace (07-21-2017)
I had one tire going low, it was the tpms sensor. Sprayed some soapy water and could see bubbles.
At the BMW UDE, the instructor had the tire pressure screen up, probably the most useful screen of all of the options. He even aired down some tires during the session. Now I check the pressures daily.
pcloadletter (07-14-2019)
I was adding air weekly on the 14, but it was out of warranty, one of the reasons for the trade. Now with the 16, I can go a few weeks, but one tire is losing air.
I have had to replace all 4 TPMS sensors and valves when I replaced my latest set of tires. Unexpected $1000 cost.
I have a 2013 TL. I have been experiencing the same problem. All 4 tires are losing all. One tire in particular was at a faster rate than the other three.
I drive far from my home base frequently so I have a full size spare in addition to my donut spare.
So I swapped the most leaky tire with the spare and gave the wheel a good inspection. Tire was fine.
I then sprayed a soap solution on both beads. Didn't see a leak.
Then I sprayed the valve stem. Bubbles galore. I did over inflate the tire for the test.
The leak was from the base of the stem.
I then deflated the tire and popped the tire bead.
I then proceeded to unscrew the TPMS nut to remove the sensor.
There was a lot of white dusk. Thought it was just road dirt stuck in the crevice around the stem.
After I pulled the TPMS from the inside and inspected it.
The white dust was embedded in TPMS threads and also worked it way onto the rubber grommet.
From this I concluded that the aluminum corroded from the road salts and I need to replace the entire sensor and clean the wheel as best I can.
Questions -
1.) Has anyone else seen this on their wheels?
2.) I am concerned that the grommet contact surface will not be completely smooth, Should I apply a sealer of some sort to the grommet when I install the new TPMS?
Thank you in advance for thoughts/recommendations.
Questions -
john46992
09-14-2007 07:44 PM
