trunk would not open
Old May 14, 2015 | 11:12 PM
getakey's Avatar
got to car and tried to open trunk with button at trunk
would not work, tried many times
unlocked car still would not open
tried fob trunk open - no
tried trunk open in car - no
started car and stopped, finally got trunk open
only thing I can think of is it rained today - very unusual as we are in drought
Old May 15, 2015 | 06:08 AM
RLX-Sport Hybrid's Avatar
That is odd. Did you hear it click when you touched the trunk open button on the door? Maybe it opened but the rubber seal was sticky from the heat so the trunk did not flip up? Just a thought.
Old May 15, 2015 | 06:26 AM
R. White's Avatar
This also happened to me once. Another gremlin hiding in the code ?
Old May 16, 2015 | 12:26 PM
getakey's Avatar
Would not click - I thought it might be stuck, but no.
After starting engine and turning off, I used button in car and trunk popped open all the way
Old May 22, 2015 | 03:30 AM
krava's Avatar
Isn't there a button you can push under the trunk to open it? I tried to open it with the button and it won't. It will open with the keys or the button in the car or am I doing something wrong?
Old May 23, 2015 | 06:48 AM
Limelight's Avatar
The button on the trunk won't work, for obvious reasons, unless you have the key fob on you - did you try it without your fob nearby? If not, then perhaps your button needs repairing.
Old May 23, 2015 | 06:56 AM
woropallo's Avatar
There is a rubber button, near the camera that you press to open the trunk. Look in your manual and you will see where it is located. Sometime, I find myself having to feel around to find it.
Old May 23, 2015 | 07:06 AM
George Knighton's Avatar
Grandpa
You must be carrying the transmitter, or whoever has the transmitter needs to be close.
The button on the outside is to the right of the camera, mounted under the lip. It's not visible to the casual observer.
Old Jul 7, 2016 | 08:05 AM
R. White's Avatar
This happened again. Car unlocked. Fob in pocket. Could not get into trunk until I started the car.
Old Jul 7, 2016 | 08:30 AM
miner's Avatar
With my car in my garage, transmitter in MBR closet, I can open my trunk with the button if car is unlocked - should it be like this?
Old Jul 7, 2016 | 09:05 AM
pgeorg's Avatar
Yes i believe it is. I will try it in a couple of hours and confirm.
Old Jul 7, 2016 | 09:17 AM
pgeorg's Avatar
It could be the trunk lid latch:
Or the Trunk lid opener solenoid relay.
This would be something the Service Department could figure out.
Old Jul 8, 2016 | 07:01 AM
R. White's Avatar
Thanks. Happened again yesterday. Another trip to the dealer !
Old Jul 9, 2016 | 07:45 PM
pgeorg's Avatar
I tried it and that is how mine works. If the car is unlocked, and i don't have the key fob with me the trunk opens with the button (next to the backup camera).
Old Jul 9, 2016 | 09:15 PM
Ken1997TL's Avatar
Are you standing directly behind the trunk or to the side? It won't work properly if you're to the side.
Old Jul 10, 2016 | 09:24 AM
R. White's Avatar
During all three times that the trunk wouldn't open, neither the trunk button on the FOB nor the trunk button on the driver's door would work. It only opened after the car was started.
Old Jul 18, 2016 | 08:03 AM
miner's Avatar
I experienced the same issue yesterday. My fob was in the same pocket as my iPhone. Once I removed my iPhone the trunk released.
mlody
Dec 4, 2019 02:11 PM
baelim
May 10, 2018 09:53 AM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
