Need help RLX Permanent DTC Codes
Old Today | 12:01 PM
anudeep1952's Avatar
I’m planning to buy a used 2018 Acura RLX Technology Package.
I had a mobile PPI done because the dealership only allows on-site inspections, which I understand. The PPI mechanic also scanned the car and shared the diagnostic report. The scan showed 6 DTCs, and all of them were listed as “Permanent DTC.”
I’m still learning about this, so I had to rely mostly on the PPI mechanic. My main question is: what exactly do Permanent DTC codes mean?
When I asked the dealership, they said these are not active/live codes. They said Permanent DTCs usually refer to past codes and mentioned that the car had been sitting idle for around 6 months before they bought it from their customer. According to them, the battery may have died or gotten weak during that time, which could have triggered these codes.
However, the PPI mechanic said he has not really seen permanent codes like this before, so he is not completely sure whether Permanent DTCs always mean past codes and definitely not active/live issues.
I do not want to rely only on the dealership’s explanation. Can any RLX owners or Acura/Honda techs confirm whether Permanent DTC codes usually mean past/non-active codes, or whether they can still indicate a current issue?
I have included the scan output below.Here is a copy/paste ASCII version that closely resembles the TOPDON report layout:
Code:
        ACURA-ACURA RLX-2018_维修前_FULL SYSTEM REPORT
 SN:                         11024415A1002J
 Repair Shop:                --
 Report Number:              TOPDON1779477181
 Phone Number:               --
 Date Created:               2026-05-22 15:13:01
 Address:                    --
 Scan me!
                              VEHICLE INFORMATION
 Plate Number:               --
 Diagnostic Time:            2026-05-22 15:13:01
 Make:                       ACURA
 Vehicle Software Version:   V2.60
 Model:                      ACURA RLX
 Diagnostic Application Ver: V3.70.003
 Year:                       2018
 VIN:                        -------
 Mileage:                    ---- km
 Diagnostic Scan Path:       Automatic > USA > ACURA RLX > 2018
 Engine:                     --
 Customer:                   --
 Sub Model:                  --
 Customer Tel.:              --
 Technician:                 --
 Technician Phone:           --
 Ticket No.:                 --
                                   SUMMARY
 19 systems were scanned, and 4 of them were detected with DTCs.
 Altogether 6 DTCs were found.
 For safe driving, please read the report carefully and perform related repair
 in a timely manner.
                         FULL SYSTEM REPORT (19) - PRE-SCAN
| No | System                                                      | Status      |
|  1 | PGM-FI (Programmed Fuel Injection)                          | No fault    |
|  2 | ACM (Auxiliary Control Module)                              | No fault    |
|  3 | AT (Automatic Transmission)                                 | No fault    |
|  4 | ABS (Anti-Lock Braking System)                              | No fault    |
|  5 | SRS                                                         | No fault    |
|  6 | SWS                                                         | No fault    |
|  7 | EPT (E-Pretensioner)                                        | No fault    |
|  8 | EPB (Electronic Parking Brake)                              | No fault    |
|  9 | EPS (Electronic Power Steering)                             | Fault    1  |
| 10 | BODY ELECTRICAL                                             | Fault    3  |
| 11 | Gauge Control Module (Diag-CAN)                              | No fault    |
| 12 | TPMS (Tire Pressure Monitoring)                              | No fault    |
| 13 | CAN Gateway                                                 | No fault    |
| 14 | One-Push Start (PCU)                                        | No fault    |
| 15 | One-Push Start (BACKUP ECU)                                 | No fault    |
| 16 | KEYLESS ACCESS System                                       | No fault    |
| 17 | Integrated Driver Support System                            | No fault    |
| 18 | Blind Spot Information / Cross Traffic Monitor              | Fault    1  |
| 19 | Precision All Wheel Steer                                   | Fault    1  |
                    1. EPS (ELECTRONIC POWER STEERING)
| DTC         | Description                                   | Status         |
| U0416-68    | VSA System Malfunction                        | Permanent DTC  |
                            2. BODY ELECTRICAL
| U0199       | MICU lost communication with power window     | Permanent DTC  |
|             | master switch                                 |                |
| B1A06       | Auto High-Beam (High-Beam Support System)     | Permanent DTC  |
|             | camera blocked failure                        |                |
| U0199       | Power seat control unit lost communication    | Permanent DTC  |
|             | with PW master SW                             |                |
          3. BLIND SPOT INFORMATION / CROSS TRAFFIC MONITOR
| B18DB       | Left Side BSI Radar Unit Received The         | Permanent DTC  |
|             | Audio/Navigation Unit Failure Information     |                |
                       4. PRECISION ALL WHEEL STEER
| C1621-13    | Right-Rear Precision All Wheel Steer          | Permanent DTC  |
|             | Actuator Circuit Open                         |                |
                                  DISCLAIMER
 This diagnostic report is provided for the purpose of displaying diagnostic
 data and is for reference only. It does not constitute any judgment,
 conclusion, or basis for action. The Company shall not be liable for any
 decisions or actions taken by the user based on the content of this report.
 When a user chooses to save the diagnostic report in the app, the relevant
 report content will be stored in accordance with the app's functional
 requirements for the purpose of subsequent access.
                              END OF REPORT
edwardtja
ILX
Sep 26, 2024 08:25 PM
TampaRLX-SH
3G RLX (2013+)
Mar 15, 2014 12:12 PM
slick230
May 20, 2009 12:19 PM
EricL
Jun 25, 2001 03:46 PM
EricL
Jun 23, 2001 06:43 PM
