Front defrost question
2018 RLX
When I use the front defrost button to clear the foggy windshield I noticed that the A/C light is not on.
As far as I remember the cars are utilizing the A/C compressor to remove the moisture from inside the car.
is it on purpose?
is it on purpose?
if it's pulling fresh air then i don't think A/C is needed. i don't remember A/C on with that in my 17 MDX
mrgold35
Do you live in a low humidity area? Humidity is usually in the low double digits in the southwest. Interior window fog doesn't happen very often and heat with or without A/C works equally as well to clear it out. Sometimes, it is faster to roll down the windows for a few minutes when driving if cabin heat hasn't kicked in yet.
