Crazy issue with rlx
Hi all. First post here but I’ve been lurking around for a while. So i have a 2014 rlx navigation trim with 23000 miles. Yes, 23000 miles. The issue that I am having is when I go to adjust the side mirrors they will start moving automatically to the endpoint and just start clicking. It’s very difficult for me to control it back to where I need them. I did notice that the button will push down which does make it a little easier to control, but still not perfect. The only way to get the mirror to stop once I have it where I want it is to slide the switch to the middle of left and right, otherwise it will keep moving. Note that I am using fob 2 and have not tried with fob 1 as I need to replace the battery. Any help on this issue would be greatly appreciated as it’s driving me nuts!!!! Thanks for all of your help!!!!
I had a similar issue with my 08 RDX and 11 MDX passenger side mirrors. I narrowed it down to dried up lubrication or gunked up lube behind the mirror. I just moved the mirror selector in the middle to limit mirror movement in reverse. I just adjusted as needed manually if the memory seat side mirror setting didn't work 100%. There are YouTube vids on how to pop out the mirror and re-lube. I was too worried about cracking the glass to give it a try.
hondamore (02-14-2024)
Sounds like what my mirror were doing when I had the mirror adjust switch selected to the right passenger mirror. It was trying to adjust and clicking like crazy to my memory seat position when I open the door (if my wife was the last driver), then into the down position when I place the AT in reverse, and then back to my memory seat position when I placed it into drive. It just ended up making loud clicking/clunking noise the entire time and eventually stopped moving with the mirror set in the wrong position.
Crisso
01-10-2022 06:56 PM
Jeffroe
1/2G MDX (2001-2013)
11-02-2021 07:39 PM
glujan2001
07-03-2013 04:49 PM
