2014 RLX Adv rear-end noise
I have 21XXX miles on my 2014 RLX Adv. I have had the rear actuators replaced @14xxx miles due to noise when making slight turns. The noise from the back end now sounds like gas sloshing in the tank yet it is full. Its is also sort of a low groaning sound. My wife and son recently heard it too. I have an appt for next Mon at dealer but wanted to check to see if any other owners have experienced this noise.
Have you considered turning up that excellent Krell audio system?
Forum Contributor
Received 1,392 Likes
^^ I know, just makin' a funny.
My noise is intermittent BUT happens quite often. I hear it the most when I am slowly pulling into my garage and slightly turning the steering to angle the RLX into my narrow space.
Grandpa
Received 2,609 Likes
Do you mind if I ask how the car performs at higher speeds?
Do you notice any delay in response for a high speed U, or in a series of switchbacks, or is it doing as well as it ever did?
liyhlp0nv 07 hoigh8y4q 8999
George, at higher speeds I am mostly going in a somewhat straight line with not much traversing, or switchbacks. I need to find an empty lot and give it a good test. I think the reason I hear it more pronounced as I enter my gargae is becuas of the low ambient noise. My auto-hearing is sharper than my wifes so I know if she can hear it there must be an issue.
Grandpa
Well. It's concerning, is all I can say. I hope the dealer responds correctly.
After extensive testing the noise is only apparent at low speeds - <20 mph. When going very slow and turning the wheel the noise is very noticable so I am almost positive it is the rear actuators making the sound. I did have this addressed early on so maybe with the revised TSB 13-041 out it will finally put this annoyance to rest. I will update once diagnosed by dealer.
pgeorg (05-27-2015)
i hear the same noise mostly from the rear but also sound like it's coming from the front. mostly hear it while pulling into the garage or in/out of parking spot. maybe i should have it checkout too.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
