TPMS on winter wheels
Old Oct 16, 2020 | 09:30 AM
rdx4me?'s Avatar
Anybody know if the 2020 RDX automatically 'sees' new TMPS? I have winter tires on separate wheels that have TMPS. Will the RDX auto recognize these or do they need to be programmed at the tire shop?
Old Oct 16, 2020 | 09:53 AM
Acura604's Avatar
2024 RDX A SPEC
auto recognize after you go on a short but slow drive....
Old Oct 16, 2020 | 02:07 PM
MTD's Avatar
MTD
They have to be the newer 433 mhz sensors thought. Older 315 mhz ones wont work.
Old Oct 17, 2020 | 09:07 AM
SkylineEX-S's Avatar
Absolutely correct.
I had an old set of summer wheels and tires from my old gen 2 that I thought worked as there were no error codes on the dash but after a while the error for missing TPMS did show up on the dash.
Old Oct 17, 2020 | 06:40 PM
rdx4me?'s Avatar
thanks for the info! My tire guy said the are OEM sensors. Hopefully that means the newer ones.. Guess I found out in about a month when I do winter change over!
Old May 26, 2021 | 06:48 PM
KFritz's Avatar
9th Gear
From what I have read they should auto recognize, you need to drive about 19kl/hr 10 miles per hour for a short distance. If they don't recognize the sensors , drop the tire pressure down to 20 lbs wait a few minutes & then set the tires to the proper pressure, this should cause them to trigger a low tire pressure signal & then be recognized by the vehicle. I just bought 4 sensors 42753-T6N-A01 for my new 2021 RDX so I'm hoping this will work, but I haven't tried it yet.
Old Oct 30, 2021 | 07:21 AM
axela3's Avatar
How much are the tire sensors? what size are winter tires?
Old Nov 10, 2021 | 08:33 AM
Swerny's Avatar
3rd Gear
Hi all, I just picked up a 2021 A-Spec, moving on from a 2017 Elite.
For winter wheels, I have an older set from a 2016 RDX with TPMS sensors.
I have read the new RDX won't read the old sensors.
Is the only consequence the TPMS light will be on when using the old wheels/tires/sensors?
Can it be turned off? Does it flash?
I'm debating getting new sensors or not...if i do, i will likely get new winter tires at the same time rather than paying to remount and balance the old ones which still have good tread but are 5 years old.
Thanks in advance for the help.
AcuraRDXMIKE
3G RDX (2019+)
Nov 15, 2019 01:30 PM
classiccars
3G RDX Tires, Wheels & Suspension
May 14, 2019 05:36 PM
david45
Nov 5, 2018 05:02 AM
lbouchard
1G RDX (2007-2012)
22
Oct 21, 2006 04:27 PM
