Weird crackling noise
Old 01-10-2019, 05:53 PM
4th Gear
Kaze's Avatar
Hi everyone,
I am new to the forum and is having an issue with my new RDX (weird crackling noise from center speaker area). For the last few days, dealership has been trying to pinpoint where that noise is coming from, I called them for an update earlier today and they still have no clue what is causing the noise. They took apart the center speaker and panels but apparently the noise is still there, any advice or insight will be greatly appreciated.
-I moved my phone midway through the video as I was trying to record the crackling noise better.
- RDX is only a month old and I first started noticing the noise two weeks ago.
Thank you.
The following 2 users liked this post by Kaze:
Cr7 (11-22-2021), Laura Germaine (12-03-2019)
Old 01-10-2019, 07:46 PM
Dizzyg12's Avatar
Only when driving? Sounds like a screw or piece of plastic rattling around to me.
Old 01-10-2019, 07:48 PM
4th Gear
Kaze's Avatar
yes - the sound can be heard after reaching 50km/hr and gets worse as i go faster.
Old 01-10-2019, 08:58 PM
4th Gear
Kaze's Avatar
i am getting extremely frustrated as the dealership has no answers for me - hope you guys can shed some light to what might be causing the noise.
Cr7 (11-22-2021)
Old 01-10-2019, 09:01 PM
Dizzyg12's Avatar
How bout when sitting and just revving the engine?
Have you listened under the hood?
I don’t think it sounds like speaker noise. Somethings loose in the dash.
Old 01-10-2019, 09:07 PM
4th Gear
Kaze's Avatar
haven't tried revving the car, but if the car is idling the noise is definitely not there.
Old 01-21-2019, 02:25 PM
Audi2Acura's Avatar
You ever figure this out by chance? I think I’m starting to get a very similar sound. It’s not constant but intermittent at this point. It sounds as if it emanating near the dash by the driver, possibly the top dash vent perhaps? Thanks in advance.
Old 01-21-2019, 11:56 PM
Dereileak's Avatar
it almost sounds like feedback through the center speaker. Maybe pull the fuse for the amp and see if the problem goes away?
21AcuraRDX (12-20-2022)
Old 01-22-2019, 04:22 AM
Audi2Acura's Avatar
Definitely not related to the speaker. Not that kind of sound.
Old 01-31-2019, 09:25 AM
JustAnotherOne's Avatar
I have started hearing the same crackling sound intermittently. I feel it is coming from somewhere on the left side of stearing wheel column/dash area. I hear it only when the car goes over rough roads and there is a slight vibration. But I don't hear it always. I have been trying to pin point bug since it happens only while driving, it's a little difficult. Please post any updates here if you are able to find a fix or pinpoint the source. I will do the same in case I get to it.
Cr7 (11-22-2021)
Old 01-31-2019, 11:01 AM
Audi2Acura's Avatar
I actually determined the source of mine. Haven’t had it looked at as of yet. Mine sounds like it’s coming from the dash area, but it is actually related to something loose on the brake pedal. If I very lightly but rapidly tap on my brake pedal, it makes a rattling sound. Therefore, when I’m rolling over rough ground, it’s the pedal that is rattling.
Old 02-04-2019, 09:35 AM
joe424242's Avatar
exactly the same sound i got from my 19 RDX too. Mine is from the center speaker grill. Try pressing your screen or grill down to see if you are able to stop the noise. Let me know.
Old 02-04-2019, 07:35 PM
I tired hearing for the source, but does not seem to come from the brake pedal or the center speaker. Although when I tried tapping the brake pedal, I do hear a very mild crackling sound. But I am pretty sure it is not the source of mine. One thing I noticed is that the actual sound has stopped since temprattem went up yesterday.
Old 03-21-2019, 05:32 AM
6th Gear
Faithg's Avatar
RDX 2019 Clicking popping sound
I have a similar issue, the sounds started 2 weeks after I bought the car, when I increase speed the sound gets louder. It’s very frustrating because the dealership is unable to duplicate the sounds. I’m pretty sure that the noises are coming from all of the front speakers. They dealership is sending in an engineer to see if they can locate and fix it. This is a random sound, gets worse as the weeks pass by. Sometimes it sounds like the front windshield adjustment, or small pebbles hitting the windshield.
Old 04-02-2019, 10:04 AM
RRBUDDY18's Avatar
I've had this problem for about a month now, and it's not easily reproduced. Here is what happens to me:
- It's definitely coming from the center dash speaker.
- It's on and off: sometimes during my half-hour drive it's constant, sometimes no crackling at all
- The crackling volume varies, sometimes louder, sometimes softer
- Doesn't seem to depend on the environment -- electric poles, EZpass booths, etc.
- I can hear it when the radio is on, when the radio is off.
- I thought it was interference from my cell phone, but it's not.
- I turned down the center speaker volume from the settings menu, but the static/crackling still persists.
- AND, it crackles when the car is off as follows: after shifting to park, press ON/OFF button to turn off
the engine, crackling still persists. Now I open the driver side door, and the crackling is gone.
I'm guessing it's interference from the electronics, but I don't think it's a top priority issue for Acura.
The following 2 users liked this post by RRBUDDY18:
21AcuraRDX (12-20-2022), Laura Germaine (12-03-2019)
Old 04-02-2019, 11:14 AM
6th Gear
Faithg's Avatar
Clicking Noise
Hello and thank you for responding. I’m still having the difficulties. Acura is going to fly in a specialized engineer. Let’s keep our fingers crossed!!
Old 04-03-2019, 09:18 AM
RRBUDDY18's Avatar
This is an update to my last post:
"- AND, it crackles when the car is off as follows: after shifting to park, press ON/OFF button to turn off
the engine, crackling still persists. Now I open the driver side door, and the crackling is gone."
I tested again, and the sequence is:
- shift to park
- press engine start/stop button to turn off the engine
- the crackling still persists
- open the driver side door and close the door, crackling still persists
- wait a minute or two, and then the crackling goes away --> I assume the car is really "off" now.
- but then get out and get back in, the display between speedometer/odometer does the fancy
acura thingy, and the crackling comes back
I can't figure out what starts the crackling. It's so intermittent, but it sometimes lasts during my
entire drive, and other times I don't hear it at all. I think I turned off the bluetooth in the settings
but that didn't help.
Old 04-06-2019, 10:20 AM
RRBUDDY18's Avatar
This crackling noise is now happening to me all the time. As soon as I unlock the car,
get into the driver's seat, close the door, the crackling starts without me turning on
anything. The crackling isn't so noticeable when I have the radio on, but it's so
annoying. Most likely, I will take the car to the dealer when I can't stand this noise
anymore.
Old 06-03-2019, 09:28 AM
RRBUDDY18's Avatar
Update #1: So I took the RDX back to the dealer. They replaced the center speaker and a "harness" that took 2 weeks to arrive. And.....the static crackling noise is still there. In fact, it seems to be worse now. So the RDX is back at the dealer, and who knows how long it'll take to fix.
Cr7 (11-22-2021)
Old 06-03-2019, 05:21 PM
joe424242's Avatar
that is the fear and risk that I did not want to take. I had the same issue from the center speaker grille. I was afraid of getting worse after dealer takes it apart and put it back. Dealer also recommended not to.
Sorrry for your situation. I know it is frustrating. I fixed my prob by inserting a firm foam in between the monitor and the grille to press it down. It works so far
Old 06-05-2019, 08:59 PM
Midwestuser1's Avatar
Something to try if you haven’t done so yet. I had what I thought was a blown speaker on a 2009 Acura MDX (center speaker). When I pushed down on the speaker grill the noise stopped. With the expansion/contraction that happens over time the speaker grill might just be “vibrating at times from certain frequencies or road surfaces” and it sounded just like a blown speaker. So try pushing down on your speaker grills to see if you can get the noise to go away. Simple enough to try just to rule that possibility out.
Old 06-06-2019, 05:30 PM
RRBUDDY18's Avatar
Update #2: I'm kinda happy to report that this noise is now gone (at least for 3 days now) after they "reset/rebooted" the amp. However......a new issue has appeared, but I'm not going to bring the car back to the dealer because I'm pretty sure they won't be able to fix it (and also because I don't want to leave the car with them for over 3 weeks to have them wait 2 weeks for a harness to arrive).
So to summarize, the crackling static noise was totally fixed after the dealer replaced the center speaker + harness AND THEN reset/rebooted the amp.
So you ask what the new issue is? Now, there is a low level hiss coming from all the speakers (even with the radio off and with the car/engine off): most prominent from the center speaker, lower volume from the door speakers, and very little from the roof speakers. I suspect it may be due to (a) poorly shielded wires or (b) a crappy amp. Anyway, it's not bothering me as much as the crackling static, so I'm gonna leave it as is.
Old 06-06-2019, 05:42 PM
RRBUDDY18's Avatar
Update #3: This is a FYI in case others have this problem. My specific case was a first for the service dept. However, the service manager himself experienced this problem with a different RDX, and his fix was to "un-plug and re-plug" certain wires/connectors in the dashboard infotainment area. They actually tried that first with my car, but the problem persisted - hence the new speaker, new harness, and rebooting the amp.
Old 06-10-2019, 02:17 PM
joe424242's Avatar
i believe the new issue you are talking about is ANC system. please confirm.
Old 06-11-2019, 04:59 PM
van mccarty's Avatar
I had a rattle, but it was due to a loose A pillar on the driver side that flapped around on the dash....
Old 06-20-2019, 10:19 AM
RRBUDDY18's Avatar
What is the "ANC system"?
Old 06-20-2019, 10:37 AM
quantum7's Avatar
ironically....active noise cancellation
Old 06-20-2019, 03:40 PM
RRBUDDY18's Avatar
I couldn't find the ANC System description in the Owner's Manual. Does this really exist? The dealership didn't mention this to me, so if it does exist, it doesn't / didn't seem to work very well. Anyway, it's been a couple of weeks, and so far, no more crackling noise from my center speaker (fingers crossed).
Old 07-14-2019, 11:43 AM
Bomboxmoa's Avatar
Bump
Old 11-10-2019, 03:12 PM
konyo1's Avatar
Reviving this thread as my 2020 a spec started doing this every time I drive it. It’s driving me crazy.
Anyone find a lasting fix?
Old 11-10-2019, 04:42 PM
leomio85's Avatar
Sounds like an ANC bug to be honest. Doesn't sound like a typical interior rattle, but a crackling like when I speaker gets blown out. I also have a '20 A-Spec with 4k miles and don't have this issue yet. Then again, it might just be that the actual interior rattles galore in the interior have masked this noise for me.
Old 11-17-2019, 10:38 PM
5th Gear
ThunderGod's Avatar
Been through hell with this. It is the Amplifier(!), going bad. It will get worse as time goes on. It is odd when it changes with speed. For me, it sounded like the windshield was coming in on me. Scary!
Bottom line, fixed! Dealer replaced the Amp and all is good.
Old 11-18-2019, 08:34 AM
konyo1's Avatar
t
Can you scan and upload the work order so we can see the parts they replaced?
I am going into the dealer this Thursday for squeaky front brakes and a noisy rear hatch but also want to point this out. Mine makes this noise intermittently which means of course it won't be doing it when I get to the dealer.
Did yours make noise all the time or intermittently?
thanks
Old 11-18-2019, 08:50 AM
5th Gear
ThunderGod's Avatar
Old 11-18-2019, 08:52 AM
konyo1's Avatar
Thanks for the quick reply.. it looks like they had to replace the amp twice?? Is that correct?
Old 11-18-2019, 08:53 AM
5th Gear
ThunderGod's Avatar
Mine was intermittent and impossible to identify as the sound system. Sounded like it was a windshield issue. They had my car for over a month before I took it to a different dealership, who tracked it down rather than just guessing.
Old 11-18-2019, 08:56 AM
5th Gear
ThunderGod's Avatar
They did not make comments about the second replacement, but I can assure you that the issue is fixed. I saw that they also replaced the antenna, but I think that was due to damage done by the previous dealership.
Old 11-18-2019, 09:06 AM
Mototech22's Avatar
i see where konyo1 is thinking the amp was swapped out twice, in the techs notes he states he swapped the amp then rechecked and rest everything back to factory. then he tested the car again the noise was still there so he rechecked the connections and swapped the amp, but they only put QTY 1 for the amp part number.
Old 11-18-2019, 10:03 AM
Mototech22's Avatar
i thought the same thing, but i wonder if he just installed it to troubleshoot it and then swapped it out completely. it wouldn't let me add this to my first post as it was over 15 minutes.
Old 11-18-2019, 07:08 PM
3rd Gear
Timothy Borghgraef's Avatar
Weather stripping on hood
The weather stripping thats on the hood just above the grill makes a flapping noise while driving. Had ran into this before.
Quick Reply: Weird crackling noise
