Transmission Chatter
Old Jul 6, 2023 | 03:35 PM
MRF0730's Avatar
3rd Gear
Hi everyone. I have a 19 RDX with 58k on it. All service up to date including transmission fluid about 5k ago.
On our way to Bend for vacation with bike rack and roof box and luggage. Nothing the RDX shouldn’t be able to handle. After an aggressive drive over the mountain pass and passing people (safely) the car started making a clunking chattering noise from the trans/drivetrain. Took it in and they can’t figure it out. No codes, but when it clunks/chatters it hesitates or feels sluggish. Any advice or help? See attached.
File Type: mov
Old Jul 6, 2023 | 07:22 PM
sonyfever's Avatar
Hard to tell virtually, but I noticed the engine sound changed when the nosie occured. Sounds like the throttle was released a little bit. Did you keep the same pressure on the pedal while recording the video? Also, does the noise only occur during moderate-strong acceleration?
Old Jul 6, 2023 | 08:27 PM
MRF0730's Avatar
3rd Gear
It was during moderate accel. Around 2k-3k rpm. If I get on it and accel aggressively it makes no noise. It’s just when I slowly roll on the accel (not causing a downshift but loading the current gear) and the chatter only lasts a bit. Like 2 seconds. The weird part is the hesitation I feel like when you try and accelerate a cold carb engine too fast. Or you forget the choke is on and try to ride. If that makes sense. Another video attached but it’s very short. Turn up the volume.
File Type: mov
Old Jul 6, 2023 | 09:27 PM
MyGuti's Avatar
damn, that doesnt sound good at all.
try making a longer video and see if the noise is still there if the vehicle is parked and your on the throttle.
Old Jul 6, 2023 | 11:39 PM
sonyfever's Avatar
The wastegate sounds rather loud...
The increase in boost when the noise occurred looks weird if your pedal input was constant between 1.5-2k rpm. Is the noise rpm and/or gear dependent?
I feel the noise is loud enough, that an experienced mechanic should be able to find out where it came from and gather more clues.
musty hustla
Nov 29, 2016 02:24 AM
Rockhead
May 29, 2014 08:46 AM
wasup1357
1G RDX (2007-2012)
Jun 8, 2013 08:25 AM
bgillette79
1G RDX (2007-2012)
Jul 2, 2009 08:50 PM
