Thermostat Issue?
Old Mar 6, 2019 | 06:07 PM
2019RDX's Avatar
Thermostat Issue?
It seems my RDX takes an inordinate amount of time to reach normal operating temp as shown on the temp gauge. I first noticed this when I did the last software update. After 20 minutes idling it still did not reach the halfway mark at all. I sort of forgot about it until today when I was waiting to have my car washed after a few block trip to the car wash and then idling again. Anyone else having this issue? I hate to make an hour trip to the dealership for another, “It’s a normal condition.”, from the service writer. Start up temp today was 58°.
Old Mar 6, 2019 | 06:09 PM
skarface's Avatar
Sounds like similar complaints from the 1.5L Honda engine. Do you have fuel in your oil as well?
Old Mar 6, 2019 | 06:24 PM
2019RDX's Avatar
I hope not, but I will check tomorrow. Thanks for the heads up. If there is gas in the oil my next trip to the dealership we be for a new vehicle and not an RDX.
Old Mar 6, 2019 | 10:46 PM
Wander's Avatar
I have noticed some weirdness as well. But I haven't decided if the fault lies with the analog engine coolant "thermostat" ( a rubber and metal diaphragm attached to a spring ), the temperature sensor, or the myriad computers in this rolling mainframe, which may be sending bad data to the digital temp gauge on the dashboard. ( And perhaps to the climate control system, as well ).
I doubt the analog thermostat changed with the last software update.
Old Mar 6, 2019 | 11:05 PM
skarface's Avatar
Sounds like the same problem the CR-Vs are having or this is a major coincidence. Seems like its becoming more and more clear that the RDX has the same issue as the CR-V.
Oil Dilution in Honda's 1.5L Engine - Honda Problems
Honda will attempt to fix the oil dilution problem with a service campaign that includes:
  1. Software updates to the transmission control module and electronic fuel injection system.
  2. Replacing a drain plug washer
  3. Replacing the climate control unit (in some cases)
  4. A fresh oil change
Old Mar 6, 2019 | 11:36 PM
Wander's Avatar
I believe this is confusing cause and effect.
Replacing the climate control unit is part of an effort to allow the 1.5T engine to get up to operating temperature more rapidly in cold conditions ( presumably by keeping the control valve for the cabin heating circuit closed until the engine coolant has warmed up ). According to Honda, a small amount of gasoline gets by the piston rings under normal operation, but it is slowly boiled out of the engine oil sump once it warms up. Allowing the engine to warm up faster shifts the balance away from accumulating gas in the oil.
I suppose it's possible a stealth climate control unit firmware update was included in the D.1.1.2 infotainment system update, but I doubt it. And I'm pretty darn sure transmission control unit and fuel injection system ( ECM ) firmware isn't included in OTA updates.
As for not heating up rapidly during idling, that's pretty much by design. It's hard to be efficient and wasteful at the same time. Heat = energy.
But maybe we should replace the drain plug washer, just in case? Who the heck writes this stuff, anyway? ( Honda techs are supposed to replace the drain plug washer anytime they do an engine oil change ).
Old Mar 7, 2019 | 06:18 AM
2019RDX's Avatar
My reference to the software update was the 20 minutes I spent in the RDX and happened to notice the temp gauge. The update had nothing to do with the temp gauge and thermostat, or at least I’m not aware of such. It’s just that after 10 minutes the gauge (white curved line) was only showing about a 25% rise. I know modern cars are supposed to reach normal operating temp ASAP due to emissions, etc. Several things could be wrong to cause slow warm up. I’m just old and know the thermostat is usually what techs look at first, or at least they did before digital gauges, when there was no heat from the heater and/or the gauge was screwy. Of course, grabbing the upper radiator hose was the definitive check back in the day.
Old Mar 7, 2019 | 12:11 PM
Dereileak's Avatar
there are a few factors here, what temp was outside or in your garage when this happened? Was the heater running in the car? The heater core pulls heat from the coolant to heat the inside of the car, you will notice if you have the heat off and let’s say you get the temp up half way to operating, then turn the heat on full blast, it will cause your engine temp to drop quite a bit before it recovers, if you leave the heat off until it gets up to operating temp then it will reach it faster, if you set it to auto it will keep the blower very low until it starts to build heat and then it will start raising the blower to slowly heat up the car, but In the mean time it’s causing the heat to be pulled out of the coolant, overall the systems appear to be working correctly in mine, it is very dependent on outside temp and if your heater is running. If it was -10F outside then I’m not surprised idling that long didn’t get your engine up to temp, if it was 25F then it should do it In a reasonable time, but like I said if the heater was running in the car it may of pulled a lot of heat out of the coolant, being a little 4 cylinder car, and when idling your In vacuum, it’s not surprising it takes a while to heat up by any means, they most likely designed the engine to run as lean as possible, also you will tend to notice on cold days the engine idles higher then normal to probably speed this up and help with emmisions
edit***
it was 58 degrees where the car was stored?
spamcop01
Feb 5, 2017 02:15 PM
miiipilot
Nov 2, 2008 08:56 PM
dallison
Mar 2, 2005 04:21 PM
