Sun roof squeaking
Old Jan 19, 2026 | 02:00 PM
Ccj1280's Avatar
Sun roof squeaking
My sun roof squeaks when I’m on a bumpy road. It sounds like a case of water bottles squeaking and sticking together. Any one else?
Old Jan 20, 2026 | 11:38 AM
Leaf 68's Avatar
You, and about 20,000+ other RDX owners. There is a TSB on this issue and several threads discuss symptoms and remedies.
Old Jan 22, 2026 | 09:33 AM
Optical Toxin's Avatar
Are you sure it's the sunroof? I have the same "case of water bottles" sound in mine that I haven't been able to locate, but I swear it's coming from inside from somewhere lower than the sunroof. Interestingly, only happens after the car gets wet. Once it has dried out, the squeak is gone.
Old Jan 23, 2026 | 05:28 AM
russianDude's Avatar
The TSB is primarily for popping sounds in sun-roof, squeaking is something different
Old Mar 14, 2026 | 03:19 AM
Baconsoup's Avatar
I had this EXACT issue, and described it the way to my dealer! It was something in the sunroof. I took it to the dealer to be fixed under warranty, and they fixed it, but they said it was related to a prior accident I had where the frame was slightly bent. A side-effect of this issue was when my pano-shade went all the way back, one of the clips came loose and started to sag.
Did you ever find out what was the cause of your specific issue?
Old Mar 16, 2026 | 07:16 AM
John from PA's Avatar
I can’t identify with the problem, but my dealer tells me to use the Honda rubber lubricant on all the rubber parts on the sunroof. Since I do a “detail” about three times a years that is when I use it, pretty much on all reachable rubber components. Any Honda or Acura dealer should have the product.
Old Mar 17, 2026 | 09:50 AM
Krisbo26's Avatar
Where do I find the TSB? My sunroof makes a popping/knocking sound going over bumps
Old Mar 17, 2026 | 02:37 PM
EasyLoveRDX's Avatar
I would call ahead for shinetsu grease. Dealerships stock it for use in the bays and they'll likely need to order in an unopened tube.
Old Mar 17, 2026 | 07:25 PM
GW208's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
https://www.urvi.net/forumfiles/SB/B23-004.PDF
Old Mar 17, 2026 | 10:32 PM
attofarad's Avatar
I just ordered mine, along with other parts, from Peoria Acura's online parts site
acuraflight
Sep 29, 2025 12:09 PM
Otherbmw
3G RDX (2019+)
Dec 15, 2023 02:28 PM
rey rey
Aug 3, 2008 03:23 PM
miamirice
Mar 6, 2008 02:10 AM
STC
1G TSX Problems & Fixes
Feb 9, 2006 06:02 PM
