Runaway Heat
Old Feb 28, 2022 | 01:04 PM
jcross1231's Avatar
Touring
Runaway Heat
Driving home on the turnpike a couple of days ago, the environmental system was only putting out heat when it should have been cooling. Cranking the setpoint down to "Lo" resulted in lots of fan and no cooling - 135° air coming out of the vents. Anyone else had this happen? The AC clutch is engaging. The system apparently just isn't moving the right doors to mix the air.
Old Feb 28, 2022 | 11:49 PM
sonyfever's Avatar
Sounds like the hot/cold air blend door motor could be stuck. Each side has a motor unit. 79150-TLA-A51, 79150-TAA-J41.
Old Mar 1, 2022 | 09:54 AM
jcross1231's Avatar
Touring
Thanks for the information. That's pretty helpful! After driving 150 miles and 2 additional days around town with full heat, you might know the problem wasn't present at the dealer. I just got the car back, and it's all working fine. They've never seen this issue before. They even called the factory rep. It was new to him, also. Just hoping it doesn't manifest itself again next winter after a cold snap.
Charlienesh
3G RDX Problems & Fixes
May 1, 2020 05:18 PM
mominn8266
Aug 1, 2018 11:43 PM
scatterbrain
Oct 27, 2017 11:43 AM
babyduke
3G MDX (2014-2020)
Jul 15, 2017 06:34 AM
andrew.koz
Sep 13, 2008 04:54 PM
