Read This BEFORE You Buy
Do the instrument cluster brightness buttons only work at night when it's dark? I have a 2018 loaner and the adjustment buttons work all the time day or night. Sometimes during the day the red is washed out in sunlight or otherwise too bright. I never had a car where you can't adjust that.
I agree, this is exactly how it should work. Unfortunately it is not how it works with the RDX gen3. What I determined as the weather became colder in UNY is that when the outside temp is around 68 deg F or less the system works properly. If the outside temperature is about 70 deg F or higher the recirculate function NEVER turns off unless you manually turn it off. A software update could easily correct this along with many of the other annoyances I have listed.
Cazman- my nav screen also flickers back and forth from light to dark during dusk, like it can't decide which to pick. It's incredibly annoying along with the high beams flashing everytime I'm behind a white or silver vehicle at night. I had to turn the auto high beam feature off because I already had 2 cars pull aside and I dont need a road rage incident because the feature doesn't work right.
I can’t re-test at the moment because it’s summer but I reviewed this “issue” previously when reading about it in another thread. I’m pretty positive the “recirculate” would turn off when I hit my desired temp during the summer; around 64 degrees-ish. It was in the 90’s outside consistently. I didn’t have to manually turn it off.
meant to say “not summer”. I’ll try to restest the opposite with the heating as opposed to cooling. Won’t be able to do the cooking until next spring/summer. Not planning on taking a road trip to Florida any time soon.
That connection error between the seat and steering wheel. I know it well.. after 60 years, I still haven't found a repair shop that can fix it!
On a flat road with a white car in front, the auto high beam does not go on. I am keeping an eye on this.
