Door lock issues
Acura RDX 3rd generation 2020.
Problem: since November 2021, I have intermittent problems with the lock and unlock on the driver's side door only... after 3 visits to the dealership: NADA no problem found (intermittent)
anybody else ?? the 3 others doors are working ok.
in the last visit they replace the remote control...problem came back after 3 days
I had issues where it would lock or unlock itself. Remote start wouldn’t work because thought a door was open. The driver door seal was bad and leaked and caused a sensor issue. They replaced the seal and the sensor and haven’t had an issue. I now have an issue where the door handle will freeze slightly pulled out when I get in and close the door and cannot get out unless I t roll the windows down and use the outer handle. A lot of things stick on these when it’s under 10 degrees
deepblue626
May 26, 2022 12:51 AM
thisaznboi88
Nov 10, 2013 10:39 PM
mrsteve
2G CL Transmission Recall Q & A
Jan 24, 2005 02:22 PM
