2019 RDX transmission
Hello... Do anyone of you notice a small jerk whenever the gears change in the 19 rdx?
I drove a cvt transmission car before where there is no gear change.
Now i am noticing a minor jerk(can feel the gear change) whenever transmission is changing gears.
Is that a common issue in honda’s 10 speed transmission?
You'll get use to it but it is always there. I miss my CVT too, very smooth and if it wasn't for the limited torque, I would go for a CVT again.
I've read somewhere that one owner had a transmission noise, not sure what it really sounded like, or was it a jerking problem too, but he had the dealer update a software for the transmission and it fixed his problem. I'm going to ask the dealer to do the same for me on my first oil change just to make sure mine is updated, I don't have any transmission complaints so far though.
All geared automatic transmissions will have some jerkiness when they shift, and there is a trade-off between smoothness, performance, and overall fuel efficiency.
Early production 2019 RDXs had some especially jerky shifts in the low gears, and IIRC there was even a procedure dealer service could perform to "wear-in" the clutches in the transmission and smooth things out. Or you can just drive the thing and wait for them to wear-in on their own after a few thousand miles. Mine was very early production, and it has smoothed out a lot with normal wear.
I bought my 2019 RDX Tech in September 2018 and had issues from day 1. Transmission harsh shift issue, intermittent Airbag passenger light staying on, Radio volume erratic, no station control from steering wheel, loss of audio, parking going on on its own and could not release on several occasions. Lost power passing a car at 70MPH and had to pull over and re-start car. The climate control turning itself off and going to LO mode several times. All issues brought to dealer for repairs and never could reproduce problems. Made several video recordings of these thing happening. File Lemon Law. After 9 months with this intermittent car, lost the case as dealer keeps saying operating as designed. Had 8 Acuras since 2001 and never had any issues with any until this one. Never again. I traded it in with 8400 miles as I didn’t feel safe driving this and had way too many intermittent issues. Beware!
It’s part of the design, it affects everyone, I’m sure they got it as fast as they could but there is always room for improvement, I do wish it was faster myself
If you are coming from a CVT, then a good way to tell if it's you or the vehicle is to observer the pattern and strengths of the jerks and see if they are consistent every time.
The harsh, problematic jerks that some folks are observing on their cars are inconsistent, they tend to softens after certain driving time as the car warms up.
Another way to distinguish whether it's your own experience of driving a CVT or vehicle's problem is to test drive another RDX from the dealer.
When I test droves the RDXs, I didn't notice any harshness at all comparing to my own MB truck.
To those refugees who have fled from the land of the CVT to a real transmission, yes Virginia, automatic transmissions with gears actually do change gears and it is sometimes noticeable. As a preferred manual transmission driver (I need a new left knee, after replacement of same I will resume driving my Mazdaspeed 3) I decide when and how smoothly those shifts occur, I find it comforting that my 10 speed transmission, which has more gears than any manual I know of, is actually using all of them. Our transmission is noted positively as one well programmed to chose the appropriate gear seamlessly, as opposed to some that seem to randomly select gears.
Have any of you noticed that sometimes driving in the lower gears like 3-4 it will once in awhile, pretty rare, but it feels like the torque converter does not lockup. The car still speeds up but the revs do not seem to be completely locked to the engine speeding up. It’s like if I give it more gas the RPMs will increase more then what makes sense for the car speeding up, almost like the torque converter is not locked and I’m relying on the fluid to move me. It’s only happened a few times, but it’s an odd feeling when it does happen
I haven't encountered this at all *knock on wood*. Car shifts pretty darn smooth through all the gears. At least upshifting. When slowing down, you can feel each downshift, which can be annoying while trying to brake smoothly.
It could be that the car is in a lower gear then what I was expecting and giving me this feeling
