Hondata vs. KTuner?
Old Oct 30, 2019 | 05:02 PM
  #81
leomio85's Avatar
I could be completely wrong, but I don't think anything OTA would effect the tune. More than likely OTA updates are simply an update to the infotainment and other possible software updates. Things like the ECU tune that controls AFR and timing are firmware, which requires you to be plugged into the OBDII to make the changes.
That being said, I'm sure you'd notice the power drop off if the tune did get wiped from an OTA update.
Old Oct 30, 2019 | 07:11 PM
  #82
Gearhead
An OTA update would be incredibly risky to do for the ECU. Brick the infotainment and the car still will drive. Brick the ECU and ...
Old Oct 30, 2019 | 07:59 PM
  #83
Gearhead
Looks like the latest version of the Ktuner SW is 1.0.9.2. Here is the version history but it doesn't say the RDX is in it from what I can tell u
Version History
Version 1.0.8.5 is when RDX support was added.
Old Oct 31, 2019 | 07:54 AM
  #84
Funz51's Avatar
Expanse me
Version History
the Software Version Description, or SVD, is just going to tell you changes from the last version. RDX was added in 1.0.8.5 and there have been no changes for RDX since then. I did not see a date next to the version on the website, am I missing something? That is somewhat important.. just say'in
They update quite a few vehicles, with all sorts of enhancements, which may make into the RDX. hopefully..
Old Oct 31, 2019 | 08:18 AM
  #85
Gearhead
I didn't see the tune in the version control list for the 2020 RDX but I don't know the associated ECU numbers and they are different than the 2019's. They were added about a month ago. Likely they might have just ported most of the tune over from the 2019 code.
From the times I drove it, the tune seemed pretty solid. I just wish the very solid midrange pull extended into the top end. It seems stock and tuned this motor is less of a revver than I would expect. Maybe there are some significant breathing limitation for high RPM HP. I've been tracking my car stock and it almost never shifts much beyond 6k at WOT.
Old Oct 31, 2019 | 08:39 AM
  #86
not2envy's Avatar
Maybe a upgraded intercooler and intake when they become available would help it rev out more. plus upgraded down pipe
Old Nov 11, 2019 | 06:07 PM
  #87
Funz51's Avatar
Expanse me
Originally Posted by Funz51
I will report on the stage 2 burn soon, including MPG, butt-kick measurement, rpm hanging and general 'normal' driving experience (traffic and otherwise). So far, with only some tooling around and a few WOT's, I find it awesome. Not only the power increase, but the way it handles itself with normal launches from 0, 10, and 30 mph. Very well done so far.
...also, which was mentioned by someone before, the brakes appear to be harder, and the sport steering is a bit tighter. i assume it is because they used the latest factory ECU settings as a base. My original ECU was A88.
... and I used Parallels running Win10 on my Mac laptop to burn the V1.2/ECU.
Update on stage 2 tune. The throttle delay is not gone. It comes and goes just like factory, but is less noticable. Again, this points to the tranny reaction more than the ECU tune.
The mpg of stage 2 tune did not change from factory tune. If you don't keep mashing that pedal, the tune keeps the car in as high a gear as possible and feels conservative, but it reacts faster from a mash. And when you mash, and you are moving, the turbo feels already spun up, or spins up faster/earlier, along with the 60 more lbs of torque.
I did not do any 0-60 times at this time. The published hp and torque curves should explain alot.
Old Nov 11, 2019 | 07:05 PM
  #88
Burger Steak & Eggs's Avatar
I am disappointed.
Old Nov 11, 2019 | 07:47 PM
  #89
Funz51's Avatar
Expanse me
Originally Posted by Burger Steak & Eggs
I am disappointed.
Yeah, so am I. It is a lot less though, just not gone. And again inconsistent.
Old Nov 13, 2019 | 04:18 PM
  #90
sonyfever's Avatar
FYI, I found my old OBDII scanner can read calibration identification. To my surprise, the ID is 5YF-A860. Not sure what's going on as my ECU part number is A87...
Old Nov 15, 2019 | 10:29 AM
  #91
lil12002's Avatar
Side question here. If you go with the stage II do you need to keep the k tuner control gauge connected while using the car?
Old Nov 15, 2019 | 10:45 AM
  #92
Gearhead
Everything can be removed after you load the tune. The Ktuner does have data logging capability though that can help you see what is actually going on such as knock counter to see if you have any issues with your fuel quality. For the v1_2 you'll need a laptop to collect and view this data.
Old Nov 24, 2019 | 07:33 PM
  #93
Funz51's Avatar
Expanse me
Ktuner 1.0.9.3 is now available. It says it includes the 2020 RDX tune.
Old Dec 26, 2019 | 07:28 PM
  #94
Funz51's Avatar
Expanse me
Ktuner version 1.0.9.4 is now available.
Old Dec 29, 2019 | 01:01 AM
  #95
sonyfever's Avatar
Can you check the ECU SW version in this release? It can be found in calibration ID under ECU info, if Ktuner software is similar to FlashPro.
Old Dec 29, 2019 | 10:53 AM
  #96
Funz51's Avatar
Expanse me
What does Flashpro show?
Old Dec 29, 2019 | 11:01 AM
  #97
Funz51's Avatar
Expanse me
ECU Version for Ktuner 1.0.9.4
Old Feb 22, 2020 | 03:34 PM
  #98
Funz51's Avatar
Expanse me
Update.... ktuner 1.0.9.6 ecu version is A88.
Old Feb 22, 2020 | 04:19 PM
  #99
sonyfever's Avatar
Thanks for the info. For 2019 RDX, FlashPro has been using A88 since 3.4.8 from Nov last year. Just an observation, no good or bad as both systems eventually use the latest version from Acura.
Old Apr 25, 2021 | 02:11 AM
  #100
sonyfever's Avatar
Found this post from Derek@IMW comparing the two tuning options:
https://www.imwtuned.com/blog/what-to-choose
Old Apr 27, 2021 | 01:41 PM
  #101
NBPDC505's Avatar
Seeing this list before in a post from Derek is what steered me to Ktuner for mine. Used Hondata on all of my previous vehicles, but for the new DI turbo cars Ktuner looks to be the best path forward.
Cu2Suspect
2G TSX Performance Parts & Modifications
17
Jan 14, 2014 03:08 PM
manman007
1G RDX DIY & FAQ
Nov 9, 2012 09:01 AM
gungho_15
May 4, 2011 08:42 AM
Habu
49
Mar 18, 2011 04:57 PM
Twisteds2k
Aug 17, 2006 09:49 PM
