Which AT&T plan for wifi?
Old Jul 2, 2018 | 11:47 AM
Keikowacko's Avatar
What are most folks doing? 1GB/month for $10 or unlimited for $20?
How is the wifi? I've never had it in a car. Thanks!
Old Jul 2, 2018 | 12:57 PM
oblio98's Avatar
WayTooManyAcuras
I was wondering the same thing. I use Verizon for my phone so I don't get the "discount".
Are we supposed to get 3 months free or something like that with the WiFi or is that only with AcuraLink?
Old Jul 2, 2018 | 01:20 PM
Fury63's Avatar
1GB doesn’t get you far but I suppose it depends on what you use it for. My daughters burn through our data using Spotify, Snapchat and YouTube when outside the home. It would be cheaper for me to add this as opposed to upgrading our mobile plan.
I’d go for “unlimited” (read the fine print) myself.
Old Sep 9, 2018 | 01:44 PM
jonarogers's Avatar
What discount are you referring to? If you are a current ATT customer, do you get a discount on the hotspot pricing?
Old Sep 9, 2018 | 07:11 PM
DrWoo's Avatar
If you have an AT&T Mobile Share Plan, you can add the hotspot to your plan for $10, and it counts against your shared data.
Old Sep 10, 2018 | 10:05 AM
Meto's Avatar
I have unlimited data and a hotspot on Verizon for my phone. I am setting mine up to kick on automatically when it connects to bluetooth, so I will have wifi inside the car at all times. $20 a month for AT&T is ludicrous...
Old Sep 13, 2018 | 11:19 AM
NSXFTW's Avatar
Ok, probably a dumb question so bear with me, but do you have to activate the wifi hotspot in the RDX in order to get OTA software updates for the vehicle?
Old Sep 13, 2018 | 05:50 PM
growler24b's Avatar
You should take a look at the Canadian plan prices! A complete joke. Not even an unlimited option.
https://myvehicle.att.com/#/acura/learn
Old Sep 14, 2018 | 03:53 PM
DrWoo's Avatar
Not a dumb question, and I'm not sure anyone here knows the answer at this time about how the updates will occur, but I suspect you would not need the wifi hotspot on the RDX activated. I've seen some other posts speculating that an update could be done by using your own phone as a hotspot and connecting to the unit via USB or bluetooth, or maybe even download the updates to a USB drive. I'm also thinking that you may need any of that. When I had an issue with my Acuralink, customer support connected directly to my unit remotely. And the phone app is getting some car information remotely. When I first installed it, I got some car information, and I remember seeing a message about connecting the phone to the vehicle via bluetooth to get even more info, so there does seem to be some remote communication even without bluetooth or a hotspot.
Old Sep 14, 2018 | 07:56 PM
mrblase's Avatar
I can use my residential gateway at home to check for system updates so it's not necessary to activate the RDX's Wi-Fi hot-spot with AT&T. So far there have been no updates and I get a system is up to date message when I check.
Old Sep 14, 2018 | 09:28 PM
DrWoo's Avatar
So just after posting my earlier response about updates, I was in the car in my garage (testing some 5.1 files), and I noticed a message that an update was available. So I clicked on it, it asked if I wanted to update via WiFi or usb. I never did connect my RDX to my home WiFi, and I didn’t set it up as a hotspot either, but I selected that option just to see what would happen. It proceeded to check for an update, but then said my system was up to date. How???
Old Sep 14, 2018 | 09:34 PM
oblio98's Avatar
WayTooManyAcuras
Mine has done this about 5 times since I've gotten it. Not sure why it does it.
Old Sep 15, 2018 | 07:26 AM
Madd Dog's Avatar
I got that twice. I connected through my home’s wifi.
lilsid112
Jan 9, 2012 11:04 AM
mrdeeno
Technology
Aug 20, 2006 12:08 AM
kansaiwalker1
Apr 27, 2006 04:37 PM
vasu
47
Nov 12, 2004 08:11 PM
