Heated steering wheel
Anyone here install a heated steering wheel on your RDX? Having it done by a local shop, but wondered if there were any particular tips or issues that they may encounter.
Thanks.
Thanks.
I had the heated steering wheel and running boards installed which I supplied from online purchase to my local dealer, and labor was $455. I know that is probably not helpful as it does not answer your one question...but for what it is worth.
I paid $606 all in. The steering wheel was $428, labor was $178. Hope that helps! BTW, I had also had them previously install the remote start. The best part is when I remote start the RDX, the steering wheel automatically warms up when the car temp is below a certain level. After maybe 1 minute of it being started, it is already warm. I do live in NC, so we don't get brutal cold winters, but I don't need to wear gloves, which is nice.
My dealer wanted $806 all in. Not. I bought the wheel from Curry for 375, and having a local shop install it next week. I'll let you know what that costs.
Is there really a reason why the dealer needs to install this? I heard about sensors that needed adjusted, just didn't know if it was BS.
I've swapped out steering wheels before - have the tools to do so. Just never did it on a car with electric steering.
OG
honda/acura accessories dont carry the 1 yr warranty if they are not installed by the dealer. Changing the wheel is nothing its the harnesses and rest of the install.
plus if you go independent and have an issue anywhere in cluster or steering relayed they can take the easy way out and point to that…
on my 2017 crv i did everything except the heated wheel
i had honda do it , install pdf was 20+ pages lol
I have a heated steering wheel on my ‘19 Ridgeline RTLE it was factory stock. It’s nice, but not worth $600-$800 and I live in cold climate and I ski daily.
If I had to choice a remote start would be much higher on my want list. The Ridgeline has remote start as factory install as well.
GW208 (09-09-2021)
I ended up doing this myself. Not sure if it's because I'm too cheap...or that I dislike others working on my cars.
Needless, if you are one to do your own mods, turn a wrench here or there, it's extremely simple. The directions online are straight forward and I had zero issues through all the steps. Hardest part is working the new cable management along the new wheel, as the old harness had 5 plugs and the new one has 8...but once you realize the grey plug runs along the side to the bottom - it all works out pretty well (see picture below). Only 'tricky' part you may miss...there's an existing 2 prong cable that is taped underneath. You need to remove that tape and use that plug. It's marked in the instructions...just odd that it was already there.
Difficulty scale - maybe a 2 out of 5, Just note that I did not need a gear puller for this...your case may vary. Took me about an hour an a half...not counting a 15-20 minute wait after disconnecting the battery. If I would have needed a gear puller, it would have added 10 minutes at the most.
This is the old harness - but the gray connector will come down this side of the cable management.
The two prong connector gets connected here in the new cable wire ring.
Yellow clip stumped me for a few minutes. the black strap is spring loaded...when you slide it, this disconnects.
Nothing like toasty hands on a cold day.
The following 3 users liked this post by SVTour:
Did you need to connect through i-HDS for reprogram or clear any codes? I'm willing to try myself but would rather not do the walk of shame to a dealer if it needs to be reprogrammed.
There have been no issues since my install 6 weeks ago.
I have never had a heated wheel before. Great addition. i was surprised how fast they heat up...seconds and it's warm. Also the first cr I have ever owned with heated/cooled seats. Great stuff!
Hi,
The Chicago Acura dealer is quoting $306 for labor and $806 in all for labor plus heated steering wheel. Is this a fair price? Does anyone know a good dealer in Chicago area that can help with installation if I buy the steering outside?
I just copped the flat bottom heated steering wheel for my 2020 rdx Aspec off ebay for $500. It came with all the guts. First question; did I over pay? LOL 😅. Second question; My car did NOT come with or have a factory heated steering wheel, and since new heated wheel came with all the guts, minus the air bag, i thought it would be plug and play. I was able to install it, but there is the one two prong cable left. it does not seem long enough to go anywhere but should be plugged into the a closer harness that does not exist. What am I missing?
supafamous (01-12-2023)
Ok I think I figured it out, Based on HEATED STEERING WHEEL INSTRUCTIONS I got the wheel, but I I believe I need a new cable reel that has the port for the two prong cable. Now to try and find that part number for the cable reel.
If anyone else is looking for the clock spring or reel spring part number that has the extra port for the two prong, I believe it's 77900-TJB-D62.
CLOCK SPRING
CLOCK SPRING
I think that link is bad for the instructions. I hope THIS works.
Yes, I did finish. Here is some photos of the different clock springs as well as the final product. As far as the VSA neutral position memorizations, this is news to me. I guess i missed it in the instructions. I got no errors or lights on the dash as a result, so maybe you can skip that part? I did mark the position of the wheel when i removed it.
My Acura technician friend says I probably missed the 2 pin plug and that there shouldn’t be any other process or faults showing up. Hopefully that’s the case but I don’t remember missing anything. We’ll find out when I get home tonight.
Looks like I didn’t miss anything. May have to tear it all apart again to make sure everything is seated. Very annoying. ALL the driver assist systems have warning lights.
dumb question, but did you get the right clock spring for your car? There are a lot of numbers out there for them. Also, when you replaced the clock spring, did you take the old one apart and attach the back half of it to the new one? I almost stuck it all back together when I noticed that I had one clip that didn't go anywhere and that is because I forgot the combined the old parts with the new. I hope that helps.
DIY & Save some money
I installed the heated steering wheel (part # 08U97-TJB-220C this comes with all the parts) on my 2019 A-Spec. I paid with tax & shipping $325 for it.
Start to finish it took me about 30 minutes to do because I decided to skips steps 3-6 since they're not essential steps that prevents you from installing the steering wheel.
- Pull Away The Door Seal Opening
- Driver's Dashboard Side Lid
- Driver's Dashboard Side Vent
- Driver's Side Left Trim W/Engine Start Button
- Driver's Dashboard Lower Cover
The only 2 issues I had were the vehicle angle sensor light came on which triggers 7 other lights. The other was the the steering wheel wouldn't heat.
Solution for the 1st issue was I was already scheduled for an alignment so I decided to install it the day before. I brought it in & said that these lights just started coming on recently & usually go away. I didn't tell them I just installed a new steering wheel because I didn't feel the need to let them know everything I do to the car. So they said they would take a look & cleared the codes for me at no cost. Unfortunately my code clearer couldn't clear the vehicle angel sensor code.
The 2nd issue of the steering wheel not heating was as the dealer stated "The Part is Bad here's a $975 quote to replace it" I laughed & said don't worry about it. I contacted the dealer who sold it to me & they handled the warranty & I received a brand new one without having to send the one I installed back. When I went to install the new one I noticed that the reason for the steering wheel not heating was because I missed step 22 - Remove the tape to free the vehicle 2 pin connector. To be fair the illustrations are horrible & sometimes feels like I'm looking at Ikea instructions.
Needless to say if I had listened to the dealer, who clearly didn't inspect the steering wheel, I would've been out of a lot of money. However I ended up with a new spare heated steering wheel that my 5 year old son now uses to pretend that he's driving a car.
It also made me realize to start guessing the dealership going forward.
All in all I've installed the following on my own without issue & I saved myself thousands by doing it myself & not going through the dealership
- Welcome/Puddle Lights
- Illuminated A-Spec Door Sill Trim
- Running Boards
- All the Emblems to the glossy black ones
- Splash Guards
- Roof Rails
- Rear Panel Protectors
I guess my advice is if you're on the fence about installing it is if your car is about to go in for routine service just do it yourself. Your already going in for routine service so the worse that can happen is you have to get them to clear a code for free. JUST DON'T MENTION THAT YOU INSTALLED THE STEERING WHEEL YOURSELF OR I'M SURE THEY'LL FIND SOMETHING WRONG THAT ACTUALLY ISN'T REALLY WRONG.
- Running Boards
- Splash Guards
- Roof Rails
- Running Boards
- Splash Guards
- Roof Rails
I guess my advice is if you're on the fence about installing it is if your car is about to go in for routine service just do it yourself. You’re already going in for routine service so the worse that can happen is you have to get them to clear a code for free. JUST DON'T MENTION THAT YOU INSTALLED THE STEERING WHEEL YOURSELF OR I'M SURE THEY'LL FIND SOMETHING WRONG THAT ACTUALLY ISN'T REALLY WRONG.
- Running Boards
- Splash Guards
- Roof Rails
Side note $125 for 1 month access to Honda/Acura internal service site is worth it to get as much documents from the site so you can know what they know.
- Running Boards
- Splash Guards
- Roof Rails
- Running Boards
- Splash Guards
- Roof Rails
What an amazing flex for your kid to have that kind of toy! lol. Do you happen to have any pics posted of all your upgrades to your RDX? I been thinking about doing some.
The actual part your talking about isn't the clock spring its the Reel Assembly Cable which has the extra 2 pin adapter for the Heated Steering Wheel. The part number is 77900-TJB-D62. That's if you need to order it.
They sell 2 types of Reel Assembly Cables & both have different part numbers but same description. I guess putting "Reel Assembly Cable (Heated)" is too much work.
Alright, so anyone paying attention, here’s where I went wrong. The VSA. The vehicle steering angle sensor. I paid attention to the instructions TOO much. My Acura technician friend said he doesn’t even clock it; install it, break the green tab and put the steering wheel on. When I left my driveway to go to his house, I noticed the lines in the rear view camera were angled to the left while I was backing straight out, I finally figured that was the problem. He brought home an i-HDS and hooked it up and couldn’t get a reading from the VSA so he thought it may have been fucked up but that didn’t make sense because the car sees it (aforementioned rear view camera lines). When we turned the wheel to the right a complete 360, it lined up the lines in the rear view camera. So we took the steering wheel off and rotated the clock spring/VSA as such. I assume if you just reset the car, it would eliminate the lights and if not, a short drive would allow the car to see the right parameters again and then clear the faults. BUT since he had the i-HDS, we just recalibrated everything and voila. All good!!!
SO, do NOT follow all the instructions from the box/website should you decide to do this yourself. You do NOT have to remove the side panels. Skip the first few steps that tell you to take off the side trim pieces (as mentioned in an earlier post). Also do NOT clock the VSA, just break off the green tab and put your steering wheel back in and ensure all the plugs are plugged and enjoy the warmth.
Overall, pretty easy stuff without the hiccups and such a great value for the kit. New control unit, new steering wheel and harness and VSA for $350. That’s CHEAP for a great part(s) these days. Thanks for reading!
The following 3 users liked this post by SarcasticaLy:
not sure what sensors need to be adjusted?! I'm doing one myself on my Type S TLX. just a bolt!
Dude, I am sitting at the dealer with this same exact issue. Stupid ass instructions tell you to clock the wheel and turn 3 times. Well its 2.5 or 3.5. I did 2.5 because it was a little over 5 total. I ended up with all the warning lights plus crooked back up lines. I knew that was it, and should have tried fixing it before coming up here. Did the lights go away after fixing the reel, or did you still need the VSA coded with ihds?
ScrottoBaggins (01-31-2024)
lol. Damn. Sucks. Yes, it all went back to normal. He had his work tablet hooked up and stuff so he did it proper but simply, yes, we probably could’ve just turned it to where the reverse lines were straight again and it would’ve been fine. Cuz that caused the domino effect of triggering the rest of those lights/sensors.
