Engine Air Filter Installation
Old 04-25-2019, 06:29 AM
Mark S Long Island's Avatar
Question Engine Air Filter Installation
HELP! I bought K&N 33-3096 as a direct engine air filter replacement. I consider myself handy but for the life of me I can’t figure out how to get to the existing filter. I see the housing on the front right of the engine compartment. 3 of the 4 phillips head screws are accessible. But it looks as if you got to take apart an air shroud (or something) to get to the one on in the front on the right side. I’m hoping that’s not the case because I can’t see how to do so.
Can anyone share dissemble instructions & offer photos if you have them.
Old 04-25-2019, 06:32 AM
Received 16,260 Likes on 11,971 Posts
take off the shroud...it's a air director. the shroud directs air. held in by clips, very easy to remove and put back on
Mark S Long Island (04-25-2019)
Old 04-25-2019, 06:37 AM
I don’t see how to easily remove the rubber air shroud. If you’ve done it, any suggestions you can share?
Old 04-25-2019, 06:58 AM
perhaps this can help?
The following 3 users liked this post by justnspace:
Mark S Long Island (04-25-2019), Padre Dave (04-25-2019), subin (04-25-2019)
Old 04-25-2019, 07:00 AM
to get to that; you need to remove the plastic coverings
Old 04-25-2019, 08:00 AM
Question
Appreciate the drawing however my issue is getting to screw # 15 on the front right side. And the drawing does not show the shroud coving the housing or how to remove it to get easier access to the air filter housing & that screw. Even if I got the problem screw out with a right-angle screwdriver, I think that if the shroud is not removed it might limit the height of the top housing & not provide the clearance needed to replace the filter. So, I’m back to how to take off the rubber air shroud? Do you have experience with it & can you provide guidance? Thanks
Old 04-25-2019, 08:15 AM
This rubber shroud?
and what do you think i'm doing? not helping?
Old 04-25-2019, 08:23 AM
it looks like it's held in by clips, perhaps PULL UP on the shroud.
Old 04-25-2019, 08:24 AM
justnspace, You may have misunderstood me. I DO appreciate your responses, really. Yes, the photo you shared is the shroud I’m concerned about. From your experience would you know how to take if off? Or are you inferring I should not need to & just concentrate on getting all 4 filter housing screws off & there will be enough clearance under it to remove & replace the filter?
justnspace (04-25-2019)
Old 04-25-2019, 08:25 AM
From my experience, I would remove the plastic/rubber shroud by gently prodding at it..Perhaps you can pull up on it.
This seems like it's the only way to expose #15 screw head
Old 04-25-2019, 08:31 AM
I'll take a closer look at it this weekend & see shroud is held on with clips I did not see when I looked yesterday. I'll also see it nudging it helps. Thanks
Old 04-26-2019, 04:55 AM
here another member has already done it.
Originally Posted by Dcshoesboy
I just replaced my engine air filter with the K&N one a couple weeks ago. No clips on the intake box like vehicles of yesteryear. I had to remove the plastic covering, in addition to the intake duct in order to access the three screws on the intake box. Other than that, it was a straight forward install.
as i expected, the plastic covers and the rubber air dam needs to come off.
The following 4 users liked this post by justnspace:
Duna (05-07-2019), Mark S Long Island (04-26-2019), Oscarjr83 (06-03-2020), subin (04-26-2019)
Old 04-26-2019, 07:11 AM
Thumbs up
Thanks for going the extra mile by researching. I did not see this before. Its sure to help.
Old 04-26-2019, 09:55 PM
Dereileak's Avatar
Some more removal diagrams
The following 2 users liked this post by Dereileak:
Mark S Long Island (04-27-2019), subin (04-28-2019)
Old 04-26-2019, 11:28 PM
Wander's Avatar
BTW, I hope the transmission can handle the great heaping gobs of horsepower and torque this K&N filter will unleash.
The following 2 users liked this post by Wander:
GW208 (04-27-2019), Mark S Long Island (04-27-2019)
Old 04-27-2019, 03:32 PM
Burger Steak & Eggs's Avatar
Four more until it gets a month's worth of dust, then it will be seven less.
Old 05-16-2019, 09:05 AM
Thumbs up
Thought to share this from another forum about how to obtain access to the engine air filter housing screws. Try doing the following while engine is hot/warm since its key that rubber shroud is warm since it will be more flexible to work with.
1. Pull the rubber shroud from the bottom, not the top. In the center of the shroud is a pull tab, use a screwdriver and pull up this releases it.
2. Once done bend this shroud out of the way to undo the 4 screws.
3. You will be able to open it enough to pull out and put in your filter without having to remove the plastic cover at the front of the engine compartment
This worked like a charm the other day
The following 2 users liked this post by Mark S Long Island:
MTB (05-09-2020), subin (05-17-2019)
Old 05-16-2019, 07:47 PM
EFR
EFR's Avatar
Remember back-in-the-day when there was just one wing-nut on the very top to get the air filter out? And even better, flipping the air filter cover over to get that four barrel growl? It all used to be---so easy. Instructions and diagrams to change an air filter...no.
The following 3 users liked this post by EFR:
Ih8honda (05-11-2021), JB in AZ (05-16-2019), Wander (05-17-2019)
Old 05-16-2019, 09:35 PM
JB in AZ's Avatar
I remember that as well. But, it goes without question, that the cars today are far superior in every respect, including safety, efficiency, etc.
Old 05-17-2019, 11:46 AM
Wander's Avatar
Even better, sometimes things came with labels.
A girl I knew in high school once asked me to look at her car, because "the overhead cam is loose".
I thought that was a bit odd, but I looked anyway. The air filter cover had a big sticker on it advertising GM's most advanced engine design: "Overhead Cam".
And yeah, the wing-nut was loose.
The following 3 users liked this post by Wander:
alpine909 (05-17-2019), Ih8honda (05-11-2021), th3118 (08-14-2019)
Old 07-11-2019, 09:35 AM
Ginoj56's Avatar
How is K&N with the RDX? Any noticeable mpg, sound and performance?
Old 07-13-2019, 12:00 PM
securityguy's Avatar
You won't feel a thing...save your money unless you want it for the simple fact that it can be reused and cleaned.
Old 07-13-2019, 12:14 PM
Ginoj56's Avatar
Thanks for the straight answer. Acura may have silenced the intake too well... Accords gain more sound from the drop-in. That's why I asked.
Old 07-13-2019, 01:34 PM
Whats up security dude. Even that is overrated IMO. They are not just "flow a little water and let dry" like the literature claims. Half an hour picking bugs out of the pleats with tweezers.....no thanks.
securityguy (07-13-2019)
Old 03-24-2020, 09:37 AM
8th Gear
Raynomad's Avatar
Agree with that. K&N is overrated and a PITA to clean. Had a K&N on a Dodge diesel and never felt is was catching as much fine particles as the paper filter. Not worth an overhaul.
Old 04-29-2020, 07:23 PM
HuKaShI's Avatar
Does anyone know what the part number is for the plastic clips shown above? I broke one while trying to take it out. They are so weak. ugh...
Old 05-01-2020, 01:05 AM
Dereileak's Avatar
go look at the Lowe’s parts bin, you will find one there that’s pretty much the same
Old 05-01-2020, 04:37 PM
Madd Dog's Avatar
Received 1,024 Likes on 714 Posts
And wear a mask and gloves.
You don’t want anyone recognizing you.
vietxquangstah
10-28-2011 05:47 PM
rich9
08-01-2011 06:41 PM
pranay.jauhri
2G TSX Problems & Fixes
08-25-2010 07:50 AM
The Dougler
09-07-2009 07:54 PM
AsahiToro
04-02-2006 04:11 PM
Quick Reply: Engine Air Filter Installation
