USB Audio Test
Old Jan 19, 2020 | 02:57 PM
  #41
Oil Stain's Avatar
I too am having issues with the USB. I have tried 5 different sticks from different companies and varying sizes from 16gb to 512gb. Right now I have about 7 folders on current stick. Some folders have up to 7-10 songs in them and 2 that have 40+.
The strange thing now is I can be playing 1 folder only and I might get it to play the first 4 or 5 songs and I turn off the car to go to the store and return to start the car. The system will finish playing the current song and then jump to a random song anywhere that is on the stick, even though the current folder that was playing had 3 or more songs to go.
So if the last song title was say "Get it on", it would finish that song and then select the next song alphabetically from anywhere on the stick. I never get to hear the entire folder of 10 songs unless it is a long drive.
I have reformatted the USB sticks, tried FAT and EFAT and different file allocation sizes.
Also, I have found that if I don't use any folders and just put, say 200 songs on the stick, it seems to function better. It doesn't seem to like folders.
I'm at a loss.
Old Feb 5, 2020 | 06:13 PM
  #42
itsardx's Avatar
'20 RDX Elite
I finally got around using a USB stick with .flac (24-48), it sounded great in the car. I wonder if it would sound even better if I could get the .flac file directly without converting an mp3 (which is what I did).
XM and radio doesn't do justice to the audio system in the car. Bluetooth streaming is a bit better than the radio and xm, so was my phone connected directly.
The USB interface is buggy. One time, I started driving immediately before giving the infotainment had enough time to settle (it was still booting), it would not recognize the USB stick anymore. USB's like sd cards are always prone to issues.
When the USB was working, I was able to browse the songs and folders etc. Haven't played too much with it.
I have seen issue with the infotainment system if I jump into the car and start driving. If I take it slow, let the system boot completely, things usually work, thank you Android. Android is a crappy OS for use as an infotainment system (I use an android phone and have worked on Android based systems) and also Acura is running some old version anyways, this probably limits the usb devices that can be used.
It looks like the default behavior is to catalog the song alphabetically and play them irrespective of the location.
But I saw an option to list the folders, if you go this route, maybe it plays all the songs in that folder ?
Or maybe try to play it by Album ? I saw that option in there as well.
Old Feb 5, 2020 | 07:56 PM
  #43
itsardx's Avatar
'20 RDX Elite
If I play by Album, it seems to play everything in the folder/album. But it seems to stay in that album.
Play by folder didn't help, as it went to alphabetical order after the first song, which is weird.
Old Feb 6, 2020 | 09:41 AM
  #44
Mustachio's Avatar
Converting from MP3 to FLAC will not improve sound quality. That would be like trying to upscale a ripped VHS (480p) to 4k. You can't gain what is already lost in an MP3 so the only way to have lossless audio quality is to rip the music to FLAC. I recommend using EAC (Exact Audio Copy) to rip CDs to FLAC.
Old Feb 6, 2020 | 03:24 PM
  #45
itsardx's Avatar
'20 RDX Elite
I thought so too about the mp3 conversion, but I only had mp3s to play with. My CD drive is kinda stuck in my PC, so couldn't use the EAC app (but good to know this app works). I will have to fix the cd drive some point.
Old Feb 6, 2020 | 07:45 PM
  #46
Burger Steak & Eggs's Avatar
Last time I had to do that, it was an easy DIY and only cost around $30.
Old Feb 7, 2020 | 06:14 AM
  #47
Mustachio's Avatar
CD drives are also very cheap these days. You can buy a new one for around the same price. Internal or external (USB).
Old Feb 7, 2020 | 07:18 AM
  #48
Njbrandon's Avatar
I've had a lot of issues playing music from USB sticks. It gets stuck on loading, have to unplug and plug it in every time I start the car, etc. I started downloading music to my iPhone and it's worked flawlessly through CarPlay so I just use it through my phone.
Old Feb 7, 2020 | 08:12 AM
  #49
Padre Dave's Avatar
The only issue with using the iPhone and CarPlay is that the FLAC files won't play as such from the phone. I have some FLAC files stored on my iPhone but they are not recognized or played from my phone (iPhone 8+).
I have a separate USB with my converted files from DVD or BlueRay discs that play in 5.1 mode. That really takes advantage of our system at its best.
Old Feb 7, 2020 | 10:52 AM
  #50
Mustachio's Avatar
Apple uses its own lossless format called ALAC. Convert the FLAC files to ALAC and they will be accessible through your phone's music app just like any MP3.
Old Feb 7, 2020 | 11:02 AM
  #51
Padre Dave's Avatar
Does that ALAC format support 5.1? I will check my conversion software to see if that is an option for 5.1.
Old Feb 7, 2020 | 12:59 PM
  #52
Mustachio's Avatar
As far as I know, ALAC supports up to 2 channels. AIFF (similar to WAV) supports 5.1 but since it's uncompressed, the file size will be pretty large. I recommend using AIFF for your 5.1 files and ALAC for the rest of your lossless audio.
Also, this will be useful to know when converting:
  • CD audio is 16-bit with a sample rate of 44.1kHz.
  • DVD audio is 24-bit with a sample rate of 96kHz.
Old Feb 9, 2020 | 07:54 AM
  #53
Padre Dave's Avatar
Cool, thanks! How do I get around the “this disc contains protected material” or something like that? I own the disc, after all.
Old Feb 10, 2020 | 07:17 AM
  #54
DrWoo's Avatar
Do AIFF files playback all channels via CarPlay? Using the Apple Music app or some other app? I have not tried this, but this would get around the issue of only 1 usb input.
Old Feb 10, 2020 | 07:37 AM
  #55
Mustachio's Avatar
EAC should handle this fine. Disable autorun for your CDs as some will run software that will interfere with the ripping process. I've ripped many CDs and never had an issue.
Old Feb 20, 2020 | 08:54 AM
  #56
Snowbaby's Avatar
4th Gear
RDX USB Sucks
1st, I tried streaming using Bluetooth but the audio quality is horrible. 2nd, USB Audio is the best option but the RDX USB has so much problems: i started out with a 128GB drive, that took forever to load so I downgraded to a 8GB drive, better but still sucks. Most of the time, the car won’t recognize the drive, I had to unplug & plug it back in order for the car to recognize the drive. Very Frustrating!!! I have other cars, they all work fine. Anyway, RDX infotainment has a the Worst!!! 🤬🤬🤬
Old Feb 20, 2020 | 03:42 PM
  #57
Oil Stain's Avatar
The USB has a mind of it's own. Every time you turn off the car it seems to forget what songs it has already played. After 6-8 songs it will play the same song/songs from this morning or yesterday. Out of 400 songs with no folders, I've yet to hear at least the other 300 songs even after 4 weeks of everyday use. This is set to random play. It seems that when I hear a song I already heard, I'll manually push next until I will get to a song I have not yet heard.
Now understand I'm not complaining about hearing 1 song repeat out of 40-50. It's more like every 6-8 songs I'll get a repeat of whatever it has played since the last start up or day before.
Forget about playing them in alphabetical order, I can start with the "A" songs and go the "D's" and it will start up the "A's" again.
For me, this is really the only real complaint I have.
Old Mar 21, 2021 | 07:47 AM
  #58
mroy5150's Avatar
I was experiencing issues playing music on a USB Flash Drive. It would take a very long time to initialize and start playing. Other times it wouldn't recognize the drive at all. I would have to unplug it and then plug it in again and that would sometimes work. I moved all of the songs off of the drive onto my PC then reformatted the drive to exFAT. I then copied all of the songs back to the drive and that completely fixed the problem. Now it initializes and starts playing as soon as I turn on the car and it never looses connectivity. Problem solved.
Old Mar 21, 2021 | 12:35 PM
  #59
Jerzy's Avatar
Thank you. I've tried it before, but will try again - perhaps it is different with newer car software.
Old Mar 21, 2021 | 02:20 PM
  #60
Jerzy's Avatar
I formatted drive to ExFat and it is still the same or worse. First time after 10 minutes of "Initializing" I turned it off. Tried again with the same result. I unplugged and plugged back drive and it worked. Turned it off, open door and tried again - same thing "Initializing". Perhaps there is something different between different brands of flash drives or Mac OSX ExFat is slightly different than Windows ExFat. Bummer.
Old Mar 22, 2021 | 08:56 AM
  #61
Padre Dave's Avatar
All of the above are just part of this infotainment system. The tricks I have shared over the past 2 years are pretty much included in this discussion. There are some consistent themes that make operation less frustrating:
1. Always take the drive out of the receiving USB slot when you turn your car off.
2. When you start your car, do not insert the USB drive until you have the blue screen with the text warning to be nice and careful. Then you will have an initialization of 1-2 minutes.
3. When you reinsert the drive as in #1, you should have the infotainment system play where you were before removing the drive. The music will then continue to play.
4. Access to your directory of files takes a few minutes before it is loaded into the system. If you go to the Music Library and click on it, your directory will then be ready for you to select the tracks you want to play.
Old Mar 22, 2021 | 04:37 PM
  #62
Acura604's Avatar
2024 RDX A SPEC
^^^ too much work lol. there must be a USB device that is consistent ..i've tried 4 different drives....and all suffered through the issues mentioned above.
Old Mar 23, 2021 | 06:00 AM
  #63
mroy5150's Avatar
You would think that in two years they could have solved this problem with an over the air software update. This is one of many features that worked better on my 2013 Nissan Altima.
Old Mar 23, 2021 | 08:20 PM
  #64
Jfkmk's Avatar
You would think, right? However, instead of fixing the glitchy usb issues (along with other glitchy electronics) they worked on animating the silly graphics when you switch driving modes.
Old Mar 24, 2021 | 09:58 AM
  #65
Oil Stain's Avatar
Amen brother!!!!
Old Mar 25, 2021 | 11:45 AM
  #66
itsardx's Avatar
'20 RDX Elite
I have the Adata S102 Pro 16gb (usb 3.0). I leave it connected all the time, works just fine everytime for playing music.
I also have a Sandisk cruzer which I have used for updating maps, no issues with it either. I use a USB extension cable, as I have read some USB sticks run hot while in use. It is also less wear and tear, with switching btw usb stick and the phone.
Maybe the USB connection/wiring in the car has some issues, if you have inconsistency issues? I have read in some other thread about this.
Old Mar 26, 2021 | 07:33 AM
  #67
ELIN's Avatar
On my TLX, I wait for that blue screen before going in reverse. For a garaged vehicle, I make sure the garage door is always open so as to not build up CO. I think the backup camera (when going in reverse) disturbs the startup sequence.
Otherwise, the only fix is to park outside, turn off the ignition and restart the car!
Old Mar 26, 2021 | 09:25 AM
  #68
Funz51's Avatar
Expanse me
To ease some of this USB pain, some of us have tried USB hubs, and even USB hubs with separate switches, etc, to just make the switch to the phone and USB easier, and the resetting of the USB port easier.
I gave up trying to fool it in this way, so I made myself a little box, tucked in the center console, with a rotary switch (3 pole, 4 throw) and three usb females inside. I plug in two USB sticks inside the box, and plugin my phone USB and run that out to the phone, then another line out to the RDX USB port. Now I just rotate the switch to switch from one USB to another, or to the phone, or to unplug (where no plug is in). On the USB's, I connected the grounds altogether, and switched the pwr, and two data lines via the rotary switch.
This saves me from unplugging and plugging USB's in and out. Working well so far.
PM me if you would like pics or schematic or parts list. Not complicated, just careful soldering. Kept me off the street for a Saturday afternoon...
Desert Ridge
Sep 13, 2019 03:54 PM
JB in AZ
3G RDX (2019+)
198
Jan 24, 2019 10:30 AM
acelow
Sep 21, 2018 07:55 AM
azgirl
Nov 8, 2017 05:45 PM
Masta120
Dec 5, 2016 07:43 PM
