iPhone and CarPlay - Caller can’t hear me
Anyone having an issue where sometimes the person on the other end of the line all of a sudden stops hearing your voice during a call? I can hear them but they cannot hear me. Unplug the cable and they can hear me again. Only happens about half of the time and at random times in the call. IPhone XS.
Help! Thank you
Help! Thank you
Glen Collins (04-22-2019)
I’ve been having the same problem for a couple of weeks...no reason and no rhyme... Everything was working great after the last update. Also, this past weekend, my CarPlay conveniently disconnected itself and I had to do the 3-finger reboot. Afterwards, I had to go back into the settings to reconnect or reenable CarPlay. I’ll be glad when all the bugs and kinks are out of this system. Hopefully soon or...
Help! Thank you
Help! Thank you
I have had this happen on every car that I had my iPhone connected via USB. I believe it is an issue with the initial handshake between the phone and the car, with the issue happening randomly. My experience has been only when I originate the call. I hangup when they don't hear me when the call connects and call back and everything works.
Same issue here.
Mine usually happens about 2 minutes into the call. Usually solved by hitting the 'speaker' button to transfer the voice call to iphone and hit the 'speaker' button again quickly to have it trasnfer back to the car.
I think it happens about twice during longer calls.
Also, noticed that my music from iphone tends to skip if I plug in the phone before I start the car. This usually gets solved but unplugging the cable.
Only had my car for about 3 weeks now, but started to notice this right off the bat.
This works for me too. Thank you! Not perfect, but a decent temporary solution until the software gets fixed.
Same issue here.
I made sure I was using certified lighting cable or one out of apple box. Same thing.
Noticed one more thing today that person on the other end cannot hear me when I 'touch' the phone. Weird issue.
I have NO ISSUE whatsoever on my 2018 Accord however....
We’re not alone (see Car & Driver article below) One reason why I chose my RDX . . . Honda reliability except for those infotainment glitches experienced by those using Car Play and SiriusXM. I use neither and completely problem free after nine months. Blame Acura or Apple but this needs to be fixed before I use either. https://www.caranddriver.com/reviews...ce-20k-update/
I had this problem too. I even tried updating to the latest iOS beta in hopes it was something that Apple could fix on their end. That did not work. I also had another issue with intermittent disconnects. I read another thread that said to factory reset the RDX's infotainment system. I did this and also removed the RDX from iPhone's CarPLay settings. It has been over one week now and no one-way audio or disconnects. I inadvertently solved one problem while troubleshooting another.
I hope this works for y'all because I know it is VERY frustrating...
I have the same issue, have to hang up and call again and then it works fine. It only started happening a few weeks ago. About 1 week ago Carplay also started to randomly disconnect and reconnect every few minutes, I wonder if they are related.
firstacura19 (06-16-2019)
I experience this problem using an iPhone XS occasionally too. It seems avoidable though. I have a habit of answering/placing calls from my phone rather than the infotainment system. This is usually when it happens. Sometime's it's just easier for me to tap 'answer' on my phone's screen since it's mounted to my dash near my hand.
Same issue here.
Join the class action lawsuit. This any many other infotainment issues need to be addressed by Acura and they clearly don’t know what to do or take the issues seriously. It seems to be the only way to force them to do something.
It’s really hard to believe they released a car and system with this many bugs, this issue is one of many I noticed right away.
its free to join and only takes 5-10 minutes of your time.
The following 2 users liked this post by gqchicago:
firstacura19 (06-16-2019),
securityguy (06-08-2019)
First and last Acura.done
How do I do this?
kilroy
08-01-2009 07:26 AM
khiyal
04-02-2008 11:39 AM
Gary (Atlanta)
07-03-2005 10:32 PM
