DVD-A to 5.1 .flac, step by step
WayTooManyAcuras
Since many of us actually have DVD-A discs that we used in our older Acura's, many are asking how we can use these bought and paid for discs to create USB sticks to play in our new RDX's. Here is the step-by-step guide to do just that.
You will need the following 3 Free programs:
DVD-Audio Explorer
https://www.videohelp.com/download/D...2008.07.21.zip
foobar2000
https://www.foobar2000.org/getfile/d...00_v1.3.19.exe
foobar Free Encoder Pack
https://www.foobar2000.org/getfile/9...2018-05-22.exe
Install DVD-Audio Explorer and foobar2000. Once foobar is installed, install the foobar Free Encoder Pack. You're now ready to go!
1. Open DVD-Audio Explorer and click on the 'Open Folder' icon on the menu bar, right under the 'File' drop down menu.
2. Browse to your DVD player and look for the AUDIO_TS.IFO folder on your DVD-Audio Disc. Once you click on it, you should see an explorer view similar to the screen capture below:
3. Most DVD-Audio discs have both stereo and 5.1 tracks on them. Be sure that you select the Multichannel Files if you want the surround tracks to play in your car. You can verify which are which by looking at the info on the right. You should see info like the info displayed above. You should see Lf-Rf-Ls-Rs as well as C-LFE, which will indicate that these are the 5.1 tracks.
4. Click on the first track, hold down the shift key, then click on the last track of the group. This should highlight all of the tracks that will be ripped to 5.1 .wav files. (See the blue highlighted tracks below)
5. Press the Floppy Disc Icon at the top of the screen and the "Extract" window will open. Press the small drive icon and select where you want the files stored on your PC. I would suggest creating an empty folder for storing these files. Once the 'Output Directory' has been entered, make sure that 'Merge Groups' is checked, then leave everything default and press the large icon at the bottom of the Extract window to start the extraction. (See example below)
You will now have 5.1 .wav files in your storage directory. Now we want to convert them to .flac files so they can be tagged with artist, title and album information. For this we use foobar2000
FOOBAR2000
1. Open Foobar2000 and select 'File/New Playlist' and you should have a blank lower section of the program. Now select 'File/Add Folder' and you will see the DVD-Audio Files you ripped with DVD-Audio Explorer.
At this point it is very important to note if your DVD-Audio rip is 24-96000 or 24-48000. Since the Acura ELS system will not play 24/96 files properly, we will have to use Foobar to downsample them. If your rip shows 24-48000, then they will be fine as is.
You should see your ripped files in the foobar2000 window as shown below. Here we have 24-96000 files, so they will have to be converted.
2. Using your mouse, select all of the files that you ripped from the DVD-A. Be sure they are all highlighted. Right click in the middle of the highlighted files and select CONVERT and then the '...' at the bottom of the pop up menu. That will bring you to the CONVERT menu.
3. There are 3 things we need to setup here to begin converting these files to 24/48 .flac files.
FIRST: Click on the 'Output Format' link under CURRENT SETTINGS, and a Converter Setup window will appear. Select FLAC from the list, then press the 'Edit' button. A new window will appear. Slide the 'Compression Level' slider all the way to the left, which will set the conversion for ZERO compression. Then click 'OK'. To be safe, it's always a good idea to change the setting of 'Output bit depth' from 'Auto' to 24 bit. You can now click 'Back'.
SECOND: Set the file output destination by clicking the 'Destination' link to 'Source track folder'. This will put your .flac files in the same folder as the source .wav files. Leave everything else at default. Click 'Back'
THIRD: If your files are 24-96000 then they must be downsampled. If your files are 24-48000 you can skip this step. Click on the 'Processing' link to get to the processing window.
From the 'Available DPSs' list on the right, double click 'Resampler (PPHS)' and it should appear in the 'Active DSPs' list on the left. Press the 'Configure Selected' button and set the 'Target Sampling rate' to 48000.
Click 'OK', the 'Back' to get back to the conversion window.
Now press 'Convert'. That's it.
Now it's best to rename your .flac files to their respective song titles and copy them to your USB stick to play in your car.
That's it! If anyone has questions or finds any errors, please let me know!
:-jon
DVD-Audio Explorer
foobar2000
FOOBAR2000
:-jon
The following 15 users liked this post by oblio98:
4th Acura (07-06-2020),
97ws6 (09-01-2018),
billyt1963 (07-23-2018),
bluntman72 (09-03-2018),
Boltface (07-24-2018),
and 10 others liked this post.
oblio98 (07-25-2018)
WayTooManyAcuras
Just a quick note. If you have DTS CDs, you can convert those as well using just Foobar.
You will need the DTS decoder plug in for Foobar2000.
https://www.foobar2000.org/component.../foo_input_dts
Install the DTS plugin to your Foobar2000 installation, then just put your CD into your PC drive, open Foobar2000, create a new playlist, then from the top menu select File\Open Audio CD\ then put the tracks into the new playlist. Once there, just convert them the same way you convert the DVD-A files.
You'll now have 5.1 .flac files to play in your RDX!
This works very well. I ripped my Goodbye Yellow Brick Road DVD-A and finally got to play it today... WOW! Talk about spreading the sound around! I have never heard Funeral For A Friend sound so damn good!
oblio98 (07-26-2018)
WayTooManyAcuras
Next time you're at the dealership, have you salesman listen to your 5.1 USB's. Most of them have no clue about that capability!
Maybe some day you guys will do us the honor of sharing some of them with us, so we can get a taste of the awesome sound
I personally would be extremely appreciative!
Hi
I’ve been using one of the early PS3 to rip SACD to ISO and then convert to FLAC using foobar2000. For dvd-a I’ve been using dvdAudio extractor which will also work with some Blu-ray Discs, forbthe protected Blu-ray I have to create a backup which allows me to get around the encryption.
WayTooManyAcuras
Hi
So I finally got around to trying this. My first attempt was on Sheryl Crow's Globe Session DVD-A. I follow the instruction and get a dialogue error box stating "Encrypted stream". Am I doing something wrong?
WayTooManyAcuras
WayTooManyAcuras
You should not get an error. The only thing I can think of is that you have a DTS-CD instead of a DVD-A. I am pretty sure that disc was available as both. But if you see a ATS file then it should be a DVD-A.
Do you have another DVD-A to try? I do not represent the software, I only use it, so I really don't know what else to tell you. Anyone else run into this?
WayTooManyAcuras
If it looks like this, it's not a DVD-A
DVDAGuide - Avisynth wiki
or here
https://offog.org/git/dvdaexplorer/D...%20Manual.html
oblio98 (08-14-2018)
Trouble accessing some discs
Hi all,
I am giving this stuff a try. One of my discs from the blue man group works, one blue man group disc doesn't work. The DVD-Audio Acura demo disc doesn't work. Santana Supernatural disc works.
I am following the instructions, using a windows 10 VM running on an iMac... It is just odd that some of my DVD-A discs work and can be read, but some can't. Anyone run into this?
thanks in advance.
thanks in advance.
WayTooManyAcuras
Hi all,
thanks in advance.
thanks in advance.
I did find that if you try to go from .flac to .flac with Foobar, it won't work right. You have to start with WAV files and then convert them to Level 0 flac. I tried taking a 24/48 .flac file of unknown compression and converting it (as above) to Level 0, but the RDX would not recognize it. I had to convert the source from .flac to WAV, then back to .flac.
It's a bit odd, but it's true.
97ws6 (09-03-2018)
Oblio98-Thanks for the easy to follow DVD-A to 5.1 FLAC instructions. They worked perfectly! I am now trying to convert DTS discs to 5.1 FLAC using foobar2000. I initially got a 'can't write to the source folder with these tracks' message using the same settings as your DVD-A settings. I then used the 'quick convert' option under 'convert' and got it to work. However, the FLAC created is a little less than half the size of the file created from the DVD-A disc for a song with approximately the same length. Is the small file normal for DTS converted FLAC files?
WayTooManyAcuras
Hello. First off, I would assume that you have the DTS Decoder plug in for Foobar (or you would not get very far). However, it seems like your default settings are using compression, which is why the result files are smaller.
Do they work? If not, you might have to reconvert them.
I have found that going from .flac to .flac does not work well in Foobar, so try this. Take one of those decoded DTS files and convert it to .wav. Then convert the .wav to .flac with zero compression and see if it plays in the car. It should.
That may be what you have to do to get it to work. I've done DTS CDs without issue, so something is amiss in your setup
If you are using a Mac, you can use xAct to convert a compressed FLAC file to an uncompressed FLAC without having to go through the WAV convert.
if you need more info, let me know.
Billy
Billy
The converted files do work. I am just curious about the smaller file size compared to the DVD-A converted files. I checked the settings in Foobar2000 and the compression slider is all the way on the left.
Just figured out what I did wrong. The output bit depth in Foobar2000 was set to 'auto', which converted at 16 bit. I reconverted using 24 bit and the converted file is now about the same size as the DVD-A rips.
WayTooManyAcuras
Great. I looked at my files and they were about the same size, so I could not figure out what could have happened to your DTS files.
Ripped some concert DVD's. Quality is hit-and-miss. Eagles' Live From Melbourne sounds great, but others like Heart Alive in Seattle and Journey 2001 are just ok. I started ripping Blu-ray using DVD Audio Extractor but was not successful due to copy protection. How are you guys converting Blu-rays?
Go to Amazon and search for Bluray Audio.... there are many available but not sure how many of those are 5.1 though
What kind of music do you like? David Gilmour has a couple that are excellent. Rush and others also. It looks like more and more are being put on Bluray these days.
Received 1,024 Likes
Question, to the experts here:
Unfortunately, I have had a taste of what our sound system is capable of. So, my question is this: If I download this Layla and Other Assorted Love Songs - Classic 100 Rock | HDtracks - The World's Greatest-Sounding Music Downloads from HD tracks, would I be able to just copy it to a thumb drive and have the 5.1 surround sound play in the car?
Sylvain (06-22-2019)
WayTooManyAcuras
Wow, I had no idea the RDX was capable of playing flac files! I recently converted all of my SACD's over to dsf and my DVD-A's to flac. I think it's pretty straight forward converting the dsf's to flac. I'm also in the process of converting my 1k+ cd collection over to flac. This is another "check" in the RDX's plus box. Now, I just hope I can hold back my enthusiasm until after the new year!
It seems strange to me to design a system capable of playing 5.1 content when there's little to no 5.1 content available.
I also think most people don't give 2 shits about HQ audio. They are fine with lossy audio from whatever source is most convenient
