Wireless Charging and Galaxy S22
Old Mar 18, 2022 | 06:09 AM
gadgetfreak's Avatar
I just upgraded my phone from an S21+ to an S22 (the plus was too big for me). Now, after 5 seconds on the wireless charger, both the yellow and green lights flash together and the phone stops charging. I can reposition and it works for only another 5 seconds. I couldn't find anything in a search about this for the RDX but I found some threads on an MDX. Apparently the new metal backs on the S22 (as well as the newer iPhones) aren't compatible with the Acura wireless charger specifically - though they work with other wireless chargers. Some say you can carefully find the perfect angle to lay the phone while others say you need to wait for a fix (if any will ever come).
Any other suggestions? This would be very disappointing to me as wireless charging was one (of the many) reasons I got the RDX. Thanks in advance.
Old Mar 18, 2022 | 08:15 AM
Hou-RL's Avatar
Have you taken the phone out of the case to see if it charges. Personally I don't use the charger since it is charging far to slow for me.
Old Mar 18, 2022 | 08:30 AM
Yes I did. It is not the case. This seems to be an issue with only some wireless chargers (including Acura's) and the new phones with metal backs. But, following some advice on a different forum, I repositioned the phone on a bit of an angle (still on its back though) and just drove around the block and it stayed charging. I will need to continue tests with more aggressive driving to see what happens.
Old Mar 18, 2022 | 08:35 AM
ross7777's Avatar
Sometimes the camera bump can causes issues as well. It causes it to not lay flat enough for bigger charging pads.
Old Mar 18, 2022 | 08:47 AM
Excellent point. I am using a Spigen case which seems to even out the back a bit more but we will see. Per the MDX forums, apparently Acura has released a bulletin stating that this is a known issue since last year but there is no update on how/when it will be fixed.
Old Mar 18, 2022 | 09:01 AM
ross7777's Avatar
I've noticed it will occasionally stop charging my iPhone 12. It has a pretty big camera bump so not sure if it's due to it shifting around on the pad or what. I wonder how big the actual charing area is in the RDX? My smaller charging pad at home, which attaches magnetically is much more stable.
One thing that happens 100% of the time- I always forget my phone is on the charger after getting out of the car......
Old Mar 18, 2022 | 09:05 AM
LOL. That happened to me yesterday in Manhattan. I walked three blocks before realizing and having to go back. That never happened when I had one of those ugly dash mount holders .
Old Mar 18, 2022 | 09:45 AM
JeremyGNJ's Avatar
FYI, slow charging is better for your battery. Using quick charge reduces the long term life of the battery.
Old Mar 18, 2022 | 03:06 PM
FYI. My friend has a Q7 with a wireless charger in the center armrest. The Q7 has a reminder when you leave your phone in the charger after turning off the car. That seems useful.
Old Mar 21, 2022 | 10:39 AM
khuang94's Avatar
I own a s22 ultra and it charges on my '22 pmc with my spigen case on no problem. Hope you find a resolution!
Old Mar 21, 2022 | 04:46 PM
hand-filer's Avatar
The entire S22 lineup have Gorilla Glass Victus+ front and rear and are fully Qi/PMA wireless charging compatible. Your problem lies elsewhere, possibly the case.
Samsung Galaxy S22 5G Specifications
Old Mar 21, 2022 | 04:54 PM
I think I figured it out. It may be the camera housing. Since it protrudes from the back, the phone may not lie flat. I wonder if this is similar to a change in the iPhone in more recent models (because I saw complaints about them too). But one of the suggestions - to pivot the phone on an angle while still lying flat on the back) seems to have worked for me. I have had consistent charging for the last few days without a problem.
GreezWop
1G RDX (2007-2012)
Oct 15, 2016 12:56 PM
MKT
Sep 26, 2007 11:54 AM
Northshore
34
Jan 23, 2007 06:45 AM
flashfreaker
17
Jan 4, 2007 02:16 PM
EddieT
1G RDX (2007-2012)
Oct 1, 2006 08:42 PM
