Winter tire size for 2022 RDX aspec
baonet (11-17-2022)
I'd personally go with 255/50/19 to keep the width and diameter both the same as stock. The narrower 235/55/19 is fine if optimum snow traction is your goal, but you'll compromise dry traction and braking distances a bit by doing so. And the 255's will look better, of course. And obviously tire model will matter as well.
baonet (11-17-2022)
I threw CC2's on mine and it did excellent. I live in the midwest and it saw about 5-6" of snow though. However, that was on a 27% incline too, and still just fine. If you live in Ontario...maybe not so okay.
baonet (11-18-2022)
baonet (11-18-2022)
If you select winter/snow tires, by default you prioritize traction in extreme cold, deep snow, packed snow, ice, slush, etc. over high G-force dry traction. I’d go with 235/60-18s. I’d also research what type of winter/snow tire best suits where I live.
baonet (11-20-2022)
I'm also on 235/55/19 for my winters - I prefer the looks of a larger wheel even in winter and the cost diff between an 18 and 19 isn't that big (whereas a 20" is a fair bit more expensive and the selection is often not great).
baonet (11-20-2022)
GW208 (12-11-2022)
20s for snow is a waste of money, IMO, and 18s are ok but getting kinda chunky with those 60 area tires.
