Secondary infotainment display (on the right) has a mind of its own.
Since the latest firmware update, I've noticed recently that the secondary display on the right of the main screen seems to change without direct input. I use CarPlay 99% of the time and like to have Waze on the main portion and Spotify on the right side, which is page 1 of 3. Multiple times through a drive, it will revert to page 2, which displays something useless about being connected to CarPlay. Anyone else noticing this?
Also, anyone else having issues with the responsiveness of swiping through the pages on that secondary display? Not only is my "swipe pad" flimsy (which feels very cheap), but it usually takes a good 10 swipes to finally get a response. From that point, it seems to respond quicker.
TheDatanator (05-26-2020)
There are some things that trigger the right side to update, such as starting new directions (if I remember correctly). It’s a good idea, but horrible execution. If I tap on the “now playing” right panel in your example, it would bring me to Spotify and then the right panel would become nav (and vice versa except it doesn’t work right).
As for swiping on right, I may bring mine to dealer. It’s bad.
2020 RDX White/Espresso
I took a drive yesterday and noticed that my small screen would swap with the big screen without input. Happened a few times. This was using native GPS and airplay for music.
Yep.
I turn off my display often. Every so often, the little screen will pop open like its possessed while the larger screen remains blank. Only a stop and restart will fix it. Strange. Happens very infrequently though.
...also I should note, this didn’t happen before the update...
Had the same issue. Set up two shortcuts in Apple Shortcuts to launch maps first with an address pre loaded and then the Music app. Now both screens display the intended items without any additional set up.
doesn’t fix the the second screen randomly switching to nav for any identifiable reason...but it’s something.
jperdoch
3G RDX (2019+)
26
02-13-2020 08:39 AM
Newsy1904
12-11-2018 10:34 AM
moontz
11-09-2015 10:23 AM
