Read manual, still, how to replace engine air filter?
Old Apr 25, 2019 | 01:38 AM
Nurseman74's Avatar
I reviewed the owners manual in the maintenance section and I believe the air filter is called the air cleaner element, but doesn't show how to safely/properly replace the engine air filter. I only have 1000 miles but I'm taking this 2019 RDX to South Korea for 3 years since I'll be stationed there. I want to replace them with the K&N filters after I hit the 15,000 mile mark with the OEM filters since I had good experiences with K&N in the past. Does anyone have links/instructions to take on this task that I could access?
Old Apr 25, 2019 | 08:01 AM
Madd Dog's Avatar
I haven't seen anything written yet, but virtually all airboxes these days are held on with pop-off clips, so it should be real easy. Too, you have a good whole year to go, so give it time.
Old Apr 25, 2019 | 08:21 AM
Looks like three of the four screws are exposed, #15 will need some work to get at.
Perhaps, removing the plastic shroud, to the right of filter box. it looks like it's attached by clips...Pull up on it, perhaps?
Old Apr 25, 2019 | 10:46 AM
Madd Dog's Avatar
Yeah, I just looked. One of the screws, the drivers side front, is not easily accessible. I will just wait until a you tube person does it. I don’t know why they made it so difficult.
Old Apr 25, 2019 | 01:16 PM
neoshi's Avatar
Whatever happened to good old fashioned clips? Then again, doesn't look like there's much room in that bay... Lol
Old Apr 25, 2019 | 07:46 PM
Dcshoesboy's Avatar
I just replaced my engine air filter with the K&N one a couple weeks ago. No clips on the intake box like vehicles of yesteryear. I had to remove the plastic covering, in addition to the intake duct in order to access the three screws on the intake box. Other than that, it was a straight forward install.
Old Apr 25, 2019 | 08:14 PM
Burger Steak & Eggs's Avatar
I thought there were four?
Old Apr 25, 2019 | 08:21 PM
Wander's Avatar
It's similar in 3rd-gen MDX. You have to remove the front plastic shroud and the intake duct to get access to almost anything. But it's not hard. Just try not to lose the plastic clips.
Old Apr 25, 2019 | 09:11 PM
Dcshoesboy's Avatar
Yea, four now that I recall. Lol. I stand corrected.
Old Apr 25, 2019 | 10:32 PM
RDX10's Avatar
So that you can't do it at home. Pretty soon we won't even be able to change the tires at home.
Old Apr 26, 2019 | 10:32 AM
Dcshoesboy's Avatar
You just have to pop off the intake tube to access the driver side front screw. Takes a bit of wiggling back and forth, but eventually pops off. Then you can remove the screw.
Old Apr 26, 2019 | 07:03 PM
ULEWZ's Avatar
As a tech writer by trade, #15 is pointing towards 2 screws, in 2 locations, for 4 total. The small leader line shows the applicable #15 screws. Just thought this might help somebody. Carry on.
Old Apr 26, 2019 | 07:17 PM
ULEWZ's Avatar
Here are some pictures showing all 4 screws. The front-most left screw needs to have the rubber boot pulled away to access and easily slides back on with hand pressure only.
Front right black screw to the right and lower from the silver bolt shown.
Back right screw, closest to passenger.
Back left screw, closest to driver.
Front left screw on driver side, only accessible by removing rubber boot.
This shows how the rubber boot attaches, just presses on, but not always easy.
Old Apr 30, 2019 | 12:45 PM
jayb082's Avatar
Thanks for the pics. I'll definitely be going K&N for our 2 RDXs...used K&N on all my recent cars and no issues at all, love them.
Old Oct 17, 2019 | 06:56 AM
jayb082's Avatar
Finally got around to replacing my engine filter with a K&N. At first I was confused on how to remove the intake duct. However, it's like a rubbery plastic so it's easy to bend around and twist to wiggle off. That was the main part - after that I could get to the screws and open the filter box enough to get the old one out and the new one in. Not that difficult, definitely a DIY job.
vietxquangstah
Oct 28, 2011 05:47 PM
Dpak
1G TSX Problems & Fixes
Sep 14, 2010 03:24 PM
pranay.jauhri
2G TSX Problems & Fixes
Aug 25, 2010 07:50 AM
driver
May 17, 2008 04:19 PM
Jottle
Jan 23, 2008 09:35 PM
