No heat!
No heat!
My wife's 2020 RDX went from uncontrollable high heat in mild weather conditions to no heat in frigid conditions. She's been traveling, so it's sort of appeared as a problem all of the sudden. I took her to the airport and the heat was blowing in my face full force. When she came home and the weather had turned subzero, there's no heat?
Obviously, we're headed to the dealer, but just looking for thoughts here.
[QUOTE=RDX9149U;16862284]My wife's 2020 RDX went from uncontrollable high heat in mild weather conditions to no heat in frigid conditions. She's been traveling, so it's sort of appeared as a problem all of the sudden. I took her to the airport and the heat was blowing in my face full force. When she came home and the weather had turned subzero, there's no heat?
Obviously, we're headed to the dealer, but just looking for thoughts here.[/QUOTE
coolant level is OK?
When you returned home did you have cold air blowing in your face at full force (same force as the heated air), or was the volume of air noticiby reduced, or was it blowing powerfully from a different outlet/vent?
If airflow is the same, does the temperature gauge show the normal temperature? Do you get warm air when you raise the temperature setting to the absolute maximum.
We need to determine if the problem is due to a lack of warm coolant flowing through the heater core, or is the problem with the fan, or the selection of destination of the airflow, for example air blows from the floor vents when the defrost or face vents are selected.
mytmai2099
01-16-2020 01:43 PM
