Multiple oil changes under 15k and differential fluid change at 8k?
I have my wife's 2021 RDX, her 10% maintenance went off around 6k, I thought it was early but went ahead and had it changed. Now she is at 13k and it's at 15% again, does that seem kind of soon? Mostly city driving, no dusty/dry conditions.
Also on my 2022 RDX I'm only around 8k and brought it in for oil/tires, dealer is saying it needs to have differential fluid replaced, does that seem kind of early? Almost all highway driving for mine.
spinedoc777 (11-01-2022)
Did the maintenance minder say you needed a diff change or was it just the dealer saying it was due? It's a code 6 IIRC. If it was the MM, I'd go ahead and do it. If it was just the dealer, I'd ignore him. FWIW, mine called for a diff change just under 11k miles.
My oil change intervals are very short b/c it's full of short trips and almost all city driving, in kilometres they are: 6900, 13,500, 20,000, 25,500, 32,000. Basically every 6-7,000km or so.
This makes sense, my wife does mainly city driving, picking up our kids, running errands, etc so her oil is closer to every 6k so far. I guess I squeezed out a bit more at 8k with 99% highway driving.
You should read https://acurazine.com/forums/3g-rdx-...report-996104/ and you will be changing your oil twice as often as what MID recommends due to fuel dilution.
Not sure what metric the RDX uses to calculate the next service. I have 13k on mine, already did two oil + filter changes and the maintenance meter is showing me “B6”, so I am sure they will be pushing a diff change the next time I go in. Kind of crazy, as that’s a ton of maintenance for 13k and two years of service. Already did the engine air filter and air cabin at 8k myself for $35 - both filters off of Amazon.
NBPDC505 (11-02-2022)
More the reason I look forward to EV's with none of those fluids to changes on ICE vehicles. Acura - let's giddy-up and get some products to market.
Oil change even 6-7k with synthetic oil, that should last 10-12K miles. I get it on the rear diff, just a lot of maintenance IMO.
My wife's 2022 RDX had the "6" code show up at ~6000 miles -- if it is done at the time of the next oil change, the MM "thinks" that that would be at about 13k miles. I will change the oil sooner (2nd change, will do at ~10k miles) but may or may not change the rear diff at that time -- it's only $26 and a few minutes of my time, so I will probably just go ahead and do it when I do the oil.
tailee88
1/2G MDX (2001-2013)
05-16-2013 07:37 PM
Nbwilkin
4G TL Problems & Fixes
09-11-2012 04:22 PM
