HUD Problem - Out of Focus
Old Dec 10, 2018 | 02:41 PM
Jonathant21's Avatar
4th Gear
Exclamation HUD Problem - Out of Focus
Hi,
I just purchased a 2019 RDX Advance w/SH-AWD in majestic black pearl, 19in glint black wheels and I love it so far. Only problem is the HUD has been out of focus since I bought it. Hard to notice at first but became painfully obvious while using it at night. Dealer took it in to see if they could fix the issue. Turns out they will need to replace the HUD. Not good. I wanted to see if anyone had this issue and what the remedy was? I am worried that once they remove the old system and put in the new one.....things are not going to go back into place like new.....seems like it will take a decent amount of time and I am sure its the first one the dealership will be replacing so I am a little worried. Surgery is scheduled for this Thursday. Anyone have any experience with replacing a HUD system in the new RDX from a customer's perspective? Thanks in advance.
Old Dec 10, 2018 | 03:43 PM
RDX10's Avatar
Originally Posted by Jonathant21
Hi,
It's a relatively new car so the likelihood that someone has had this issue is very low. It is not going to be a quick fix as they will have to remove your whole dashboard. But it should be a simple and easy fix, they remove the dashboard and then simply reinstall a whole new HUD unit. They will already have the service manual and know how to remove each section, it will probably just take them a little longer.
I just suggest that you take a good look around your dash trim pieces to make sure they haven't damaged anything in the process as they can sometimes scratch or crack things as they remove them.
Old Dec 11, 2018 | 11:53 AM
Wander's Avatar
You wouldn't believe what they have to do when they install the accessory heated steering wheel for vehicles not so equipped from the factory. I amused myself by looking through some of the installation guides a while ago. If they have done any of those, they may have experience with dash surgery.
Anyway, the dash is designed to be be disassembled and reassembled upon demand. As RDX10 says, if they haven't done it many times they will just have to take their time and Read the Fine Manual.
I think some dealers have their body shops do stuff like this because they have more experience with interior trim.
Old Dec 11, 2018 | 11:56 AM
Tony Pac's Avatar
AZ Community Team
Always remember if a dealer is touching your dash, make sure they don't scratch your it. I agree with RDX10.
I don't think it's a difficult task to do...Good luck!
Old Dec 12, 2018 | 10:04 AM
4th Gear
Thanks guys for the input! I called the service department and asked for them to take their time and be careful with the install. I bought it new and I expect it back in new condition. I will go over the dash carefully upon return.
Old Dec 12, 2018 | 10:29 AM
Tony Pac's Avatar
AZ Community Team
anytime!
Yes, take 10 min and check the corners, air vents and etc. Don't go at night, go during the day time to get back your car. Also, make sure the manager knows that you won't accept any damage.
Old Jul 10, 2019 | 03:21 PM
Barb2019RDX's Avatar
3rd Gear
I am having same problem on my 2019 Advance model RDX. Dealer said they need to install a new windshield to fix. Dealer said nothing about a new HUD or removing the dashboard. I am really concerned about having this done or just living with the blurry HUD. Any other owners having blurry HUD issues????
Old Jul 10, 2019 | 04:56 PM
zroger73's Avatar
Blurry HUD's are more often the result of improperly manufactured, incorrect, or incompatible windshields than faulty HUD projectors.
The Advance trim has a HUD-compatible windshield. All other trims have a different windshield that isn't HUD-compatible and will result in a double/blurry image.
One troubleshooting technique is to hold a mirror up against the inside of the windshield. If the HUD image is clear in the mirror's reflection, but not in the windshield, then the windshield is at fault. If the image in the mirror's reflection is blurry, then the HUD is at fault.
Old Jul 10, 2019 | 05:09 PM
DriverOne's Avatar
That's actually a good thought.
Old Jul 10, 2019 | 06:20 PM
romer's Avatar
I had a periodic (yet annoying) rattle from the dash area. Tech and I took a joy ride and he quickly determined it was from around the screen. So they had to remove the dash to snug things up. They take the dash off for various things and is not worrisome. I didn't think to check for scratches in advance of the repair but it turns out they fixed the problem and no scratches or dings anywhere. You should be fine.
Old Jul 11, 2019 | 02:00 PM
3rd Gear
Thank you I will try that. The dealer is ordering a new windshield to correspond to the car’s VIN and he says that it will fix the problem. I’m hesitant to have a new car with 2500 go thru that ordeal of replacing windshield but no other fix according to dealer. Anyone else out there with having to replace windshield due to faulty HUD??????
Old Jul 14, 2019 | 09:15 AM
x_merc's Avatar
My HUD is crooked, it's canted slightly to the right and it drives me nuts. I dropped off the vehicle last week for that, sunroof rattling noises, and suspension cracking sounds around turns. They sent me an update on Friday stating they have to remove the headliner to further diagnose the sunroof issues...still haven't heard back about the HUD yet. I'll let you know what they say. I still love the vehicle, can't wait to get it back.
Old Jul 14, 2019 | 09:42 AM
NooYawkuh's Avatar
Skeptic
I have the same problem. A "klunky" rattle in the dash right near the HUD when I drive over rough roads. Something I don't think I can live with for the life of the car (and shouldn't have to) and I don't want two other rattles introduced by them trying to fix it. It occurred to me they might access it by removing the windshield and the plastic shade over the HUD, rather than removing the entire dash. But I'm glad to hear you got yours fixed. Other than that, the car is tight as a drum and this drives me nuts.
You can adjust the alignment and brightness using the buttons on the left knee panel. Have you tried that?
Old Jul 14, 2019 | 10:24 AM
x_merc's Avatar
Yes, but that only adjusts it up or down. My HUD is crooked, that adjustment button doesn’t allow that type adjustment. Thanks for the suggestion though.
Old Jul 14, 2019 | 03:16 PM
4th Gear
It is the windshield. My dealership realized it after they replaced the HUD twice. I wasn't too happy about that as I was without my brand new car for weeks. Turns out one of the laminate layers in the windshield was off.
Old Jul 16, 2019 | 03:12 PM
zroger73's Avatar
I had a "blister" in my windshield that couldn't be seen when looking through it, but it appeared as a distorted spot near the top of the HUD reflection. Drove me nuts!
Old Jul 23, 2020 | 10:44 AM
Hector Hernandez's Avatar
8th Gear
The blurry HUD display issue. If the dealer finds it to be the windshield and I have manufacturing warranty and a 7 year or 100k warranty bumper to bumper on my RDX. Will it be covered? Any assistance with my question would be greatly appreciated.
Old Jul 23, 2020 | 11:12 AM
zroger73's Avatar
Acura Care wouldn't cover this (glass is excluded), but the 4/50 new vehicle limited warranty should.
Old Jul 23, 2020 | 04:18 PM
8th Gear
What is the 4/50 new vehicle limited warranty?
Old Jul 23, 2020 | 04:21 PM
zroger73's Avatar
All new Acuras sold in the US come with a 4 year or 50,000-mile new vehicle limited warranty.
Old Jul 23, 2020 | 04:29 PM
8th Gear
Oh ok that is good to know. I do appreciate you clearing that up for me. Our Acura is a Pre-Certified Acura, so we should be covered.
Old Jul 23, 2020 | 04:39 PM
zroger73's Avatar
Glass is not covered by the Acura Certified Pre-Owned warranty. It is only covered for manufacturer defects for 4 years or 50,000 miles from the first purchase.
Old Jul 23, 2020 | 04:40 PM
8th Gear
So, my car has under 50k and it is only a 2019. We should be covered right?
Old Jul 23, 2020 | 04:45 PM
zroger73's Avatar
Actually, the new vehicle limited warranty excludes cosmetic flaws, so the dealer might try to argue that your issue is cosmetic and doesn't affect the functionality of the HUD. Hope for the best, but expect the worst.
Old Jul 23, 2020 | 04:47 PM
8th Gear
But, I should have good argument right. We had this car under 6 months.
Old Jul 23, 2020 | 08:23 PM
Jerzy's Avatar
In my RDX HUD gets a little fuzzy at low brightness only. At full brightness it is very sharp. I don't understand how focus and brightness are related, but I use it at full brightness even at night, so I don't do anything.
Old Jul 26, 2020 | 12:20 AM
3rd Gear
Hhud fix
I had my windshield replace by my dealer on my 2019 Acura RDX Advance and it’s perfect!!!!! It was the wrong (or defective) windshield for the HUD display. It cost me nothing and the windshield is PERFECT, along with the HUD display! Problem solved!!!!! Now I’m stressing about the recall for fuel pump. Not happy about that at all. No cash compensation seems unfair since Subaru had same problem and is offering cash compensation (from what I hear). My car is on recall list. I haven’t had is replaced yet. Covid keeps the car home for now.
Old Jul 26, 2020 | 08:37 AM
4th Acura's Avatar
Retired Geezer
Barb2019RDX - Are you saying your car came from the factory with the wrong windshield?
chickdr
Mar 12, 2017 09:58 PM
x95zsk
ILX
Apr 6, 2014 10:48 PM
xray328
1G RDX Problems & Fixes
Jan 7, 2011 12:13 AM
schen72
Sep 14, 2008 10:37 AM
brchitt
1G TSX Problems & Fixes
Nov 12, 2007 07:03 PM
