Engine Air Filter Dirty Quick
Old Jan 22, 2024 | 10:44 AM
RDX2O2O's Avatar
I replaced my engine air filter at 15k and it was really dirty with black soot at the bottom. Same again at 30k. Anyone notice the engine air filter gets dirty easily or is it my driving conditions and location?
Old Jan 22, 2024 | 10:46 AM
Definitely both contribute to it.
Old Jan 22, 2024 | 11:12 AM
sonyfever's Avatar
15k is not bad. With stock filter, the most I could go was 10k before the throttle response became unbearably dull. With K&N, I replace/refresh every 7k.
Old Jan 22, 2024 | 11:15 AM
RDX2O2O's Avatar
Good idea on every 10k. I notice the engine air filter is dirty when my MPG drops from 23.9 to 23.2 and I need to go to 2.5k rpm instead of 2k rpm when I accelerate to 45mph. I will try being more proactive. I was worry I was changing it too frequent as manufacturer says 30k miles which is when the notice pops up on the car.
Old Jan 22, 2024 | 12:05 PM
Texasrdx21's Avatar
Your location and conditions. Just changed mine after 10K - old one almost looked new. In dry dusty summer months, that when mine gets the most dirt. However, they are cheap on amazon to replace both the engine and air cabin filters. Add some injector cleaner to the gas twice a year too - that helps keep the injectors clean.
Old Jan 22, 2024 | 08:00 PM
achilleas101's Avatar
are you in CA or Canada around wildfires or something?
Old Jan 26, 2024 | 03:09 PM
RDX2O2O's Avatar
you are correct, sherlock holmes right here!
Old Jan 26, 2024 | 03:25 PM
Dgw7000's Avatar
K&n
I clean and re-lube my K&N filter every 10 K..I live on the East Coast. This works perfect for where I live.
Old Jan 28, 2024 | 02:01 PM
ok then, in that case Watson, to answer your question, it has everything to do with your location and environment.
smitty56
Nov 5, 2023 10:41 AM
Skirmich
1/2G MDX (2001-2013)
31
Sep 28, 2017 07:34 PM
Pista
2G TSX Problems & Fixes
Aug 15, 2012 08:29 AM
pranay.jauhri
Aug 25, 2010 07:50 AM
cristphoto
1G TL (1996-1998)
Oct 12, 2006 08:02 PM
