Driver Side Vent Question
Old Jan 15, 2020 | 05:50 PM
Nearsite00's Avatar
Hi Again - went through the owner's manual and search function on the forums, but could not find an answer.
Assuming this adjusts the amount of air the fan blows through, just want to confirm if anyone knows, and yes I did test it myself but couldn't tell the difference.
Old Jan 15, 2020 | 06:22 PM
Waetherman's Avatar
2020 RDX White/Espresso
Yepp. You might not have been able to tell the difference if you've set the CC to "auto" but if you manually adjust the fan speed you should be able to tell.
Old Jan 15, 2020 | 06:50 PM
NooYawkuh's Avatar
Skeptic
If you're trying to get heat out of those vents, you won't. Heat comes out of the floor vents under the dash and the defroster vents on top of the dash shown above in your photo. Unless you manually select those vents on the HVAC.
AC comes out of those vents though.
Old Jan 15, 2020 | 07:05 PM
kboo74656's Avatar
That wheel opens and closes the vent. That’s it. It can be wide open, partially open, or closed.
Old Jan 15, 2020 | 07:07 PM
kboo74656's Avatar
[QUOTE=NooYawkuh;16527572]If you're trying to get heat out of those vents, you won't. Heat comes out of the floor vents under the dash and the defroster vents on top of the dash shown above in your photo. Unless you manually select those vents on the HVAC.
AC comes out of those vents though.[/QUOTE
Heat comes out of my vents and ac when those are selected as per the manual.
Old Jan 15, 2020 | 09:30 PM
NooYawkuh's Avatar
Skeptic
Yeah, like I said, you have to select them manually. They won't put out heat on auto.
scatterbrain
Oct 27, 2017 11:43 AM
shizzytheking
Jul 6, 2011 05:06 AM
go_blue
Mar 2, 2005 12:23 PM
EMF213
Dec 1, 2004 09:13 PM
bloo_tls02
Jan 7, 2002 03:29 PM
