Driver Side Vent Question
Hi Again - went through the owner's manual and search function on the forums, but could not find an answer.
Assuming this adjusts the amount of air the fan blows through, just want to confirm if anyone knows, and yes I did test it myself but couldn't tell the difference.
If you're trying to get heat out of those vents, you won't. Heat comes out of the floor vents under the dash and the defroster vents on top of the dash shown above in your photo. Unless you manually select those vents on the HVAC.
AC comes out of those vents though.
[QUOTE=NooYawkuh;16527572]If you're trying to get heat out of those vents, you won't. Heat comes out of the floor vents under the dash and the defroster vents on top of the dash shown above in your photo. Unless you manually select those vents on the HVAC.
AC comes out of those vents though.[/QUOTE
Heat comes out of my vents and ac when those are selected as per the manual.
EMF213
12-01-2004 09:13 PM
